Tips and best practices for globe caches |
| Release 9.3.1 |
The information below may be helpful to you as you build and deploy globe caches.
If you already have a cache that you built using ArcGIS Desktop that you want to reuse with ArcGIS Server, then you need to
Note: If you do not have access to the parent directory of the GlobeCache directory, then you can directly register your GlobeCache directory as a server cache directory and use it with your GlobeService. No additional GlobeCache subdirectory will be created. If you use this workflow, you should make sure that this server cache directory is used exclusively for globe services.
You can also use the Globe Deployment Wizard from the ArcGlobe application to copy caches built using ArcGlobe Desktop to an ArcGIS Server GlobeCache directory. To read more about the wizard, see the topic Using the ArcGlobe Deployment Wizard in the ArcGIS Desktop Help.
