Working with ArcGIS Server |
| Release 9.3.1 |
ArcGIS Server is a Web GIS that helps you take your geographic information and make it available to others. Perhaps you've already had some experience using GIS software to create GIS resources, which are the maps, geodatabases, and other tools that you need for storing and using your geographic information. ArcGIS Server gives you the power to take the GIS resources on your computer and make them available to a wider group of users throughout a network of computers. In ArcGIS Server, the way you publish a GIS resource to others is through a service.
A service is a representation of a GIS resource that a server is making available to other computers on a network. This network can be a local one, such as your company's computer system; or it can be a broader network, such as the Internet. The computers on the network that access your service are called clients. When you use ArcGIS Server to publish a service, you are giving clients access to a GIS resource. In many cases, clients can do the same things with the service that they could if a copy of the resource were on their own computer.
As you use ArcGIS Server, you will follow a workflow of three steps to make your geographic information available through the server:
GIS resources do not originate in ArcGIS Server; instead, you use ArcGIS Desktop to create them. To determine what GIS resources you need to author, it's important to think about what GIS functions you need to perform with ArcGIS Server. The table below displays the types of GIS resources that you can publish using ArcGIS Server, what they can do, and the corresponding ArcGIS Desktop application that can create the resource.
| GIS resource | What it can do in ArcGIS Server | Which ArcGIS Desktop application creates it |
| Map document | Mapping Geoprocessing Network Analysis Web Coverage Service (WCS) publishing Web Feature Service (WFS) publishing Web Map Service (WMS) publishing Mobile data publishing KML publishing Geodatabase data extraction and replication |
ArcMap |
| Address locator | Geocoding | ArcCatalog |
| Geodatabase | Geodatabase query, extraction, and replication WCS publishing WFS publishing |
ArcCatalog |
| Globe document | 3D mapping | ArcGlobe |
| Toolbox | Geoprocessing | ArcMap or ArcCatalog through ArcToolbox and ModelBuilder |
| Raster layers and compiled image service definitions | Imaging WCS publishing |
ArcCatalog, ArcMap, ArcGIS Image Server |
From the table above, you can get an idea of what type of GIS resource you will need to prepare in order to accomplish your objectives with ArcGIS Server. For example, if you need to publish an interactive map on the Internet, then you will need to create a map document using ArcMap. Do you need to be able to type in an address and see its location on a map? Then you will need to use ArcCatalog to create an address locator.
You may have noticed that some of the GIS resources in the table above can accomplish similar things in ArcGIS Server. For example, both a map document and a toolbox can be published for geoprocessing. In these cases, the type of resource you create depends on the circumstances in which you will be using the service. You can find help for deciding which type of resource to create in the topic What types of services can you publish?
If you are unfamiliar with ArcGIS Desktop or need assistance in preparing your GIS resources, you can use the ArcGIS Desktop Help. This help system is available as part of the ArcGIS Desktop installation or online at http://webhelp.esri.com. The ArcGIS Server Help provides links to ArcGIS Desktop Help Online where appropriate.
Once you've created your GIS resource, you can publish it as a service using ArcGIS Server Manager. You can additionally use Manager to view your services, organize them in folders, monitor their performance, and create applications that make use of your services.
Publishing a service requires some preparation to make sure your GIS resource is accessible to all necessary components of the server. You should reference the resource and all of its data in such a way that all server object container (SOC) machines on your server can access it. Additionally, you must give the SOC account appropriate permissions to the directory containing the resource and its data.
When you create a service, you are asked to choose which capabilities of the GIS resource you want to enable. All service types support a base capability that is closely related to the GIS resource type. For example, all map services support the Mapping capability, and all globes support the Globe capability. However, additional capabilities may be available for a service depending on its type of GIS resource and what data and tools the resource contains. For instance, when you publish a map document that contains a tool layer, you get the option to enable the Geoprocessing capability, which allows clients to run a model on the server and see the results in the map service. Another example of a capability--one that you can enable when you publish any map service--is Mobile Data Access, which allows mobile devices to extract the map's data using a Web service. You can find a complete list of available capabilities in the topic What types of services can you publish?
By default, services are automatically enabled for Web access when you create them. If desired, you can disable Web access or set limits on what clients can do with the service through the Web. Additionally, you can specify which users on the network will have access to the services.
Once you've published your service, other users on the network will be able to access it. In some cases, you may want people to use an existing application, such as ArcGIS Explorer, to view your services. In other cases, you may need to develop a client application yourself using the tools included with ArcGIS Server.
Supported clients of ArcGIS Server services include ArcGIS Explorer, ArcMap, and ArcGlobe. In some cases, other applications may be able to consume services with certain types of capabilities enabled. For example, you could use a standard Web browser as a client to a map service with the WMS capability enabled. Additionally, if the KML capability were enabled, you could view the service with Google Earth.
ArcGIS Server Manager includes a wizard for creating your own Web mapping application that uses your services. You can choose the layers that your map will display, configure tasks that will simplify the GIS workflow, and set the theme and appearance of the application. Manager maintains a list of the applications you've created, so you can view, edit, or remove them at any time. To start creating a Web application, see Introduction to creating Web applications with Manager.
If you want to create Web applications that contain functionality beyond that provided by Manager, you can use the Web Application Developer Framework (ADF). The Web ADF contains the building blocks for creating GIS Web applications. You can use the Web ADF to build a Web application from scratch or customize an existing application that you created with Manager.
The Web ADF also provides a framework for blending ArcGIS Server services with other types of services, such as ArcIMS services and OGC WMS services. You can add all these types of services to the Web applications that you build in Manager. Also, the developer libraries included with ArcGIS Server provide the classes you need to work with these other types of services.
If you just need to embed basic mapping and query functionality into a Web application, consider using the JavaScript APIs included with ArcGIS Server. These allow you to access GIS servers through JavaScript code that runs in the browser. The JavaScript APIs work well for creating lightweight mashup applications. These might overlay data from different sources or provide simple query and geocoding functionality. You don't need to have any GIS software installed on your machine to develop or use these applications; you just need to be able to access an ArcGIS Server.
Perhaps your services will be used in the field on mobile devices. The Mobile ADF, included with ArcGIS Server for the Microsoft .NET Framework, provides classes and templates for building GIS applications for mobile devices, such as Pocket PCs and Smartphones.
Map services can expose the Mobile Data Access capability, which allows mobile devices to extract the contents of a map document through a Web service. To learn how to create this type of service, see Mobile data services.
ArcGIS Explorer is a free application included with ArcGIS Server for 3D data visualization and navigation. You can add ArcGIS Server services as data to ArcGIS Explorer and combine them with data from other servers or your own local file system.
Other possible clients of ArcGIS Server include desktop applications that you build with ArcGIS Engine, and application Web services that communicate with ArcGIS Server Web services through Web Service Description Language (WSDL).
The ArcGIS Server Help contains sections for publishing services, creating applications, administering the server, and working with geographic databases. Various tutorials are included in the help to walk you through the process of using ArcGIS Server for the first time.
You can use the Help link in Manager to open the ArcGIS Server Help system. Additionally, you can launch the help from the Start menu.
A continually updated and expanded version of the help is available online at http://webhelp.esri.com.
