ArcGIS Mobile Application Help |
| Release 9.3 |
The mobile projects that you create and manage using the ArcGIS Server Manager guide the navigation, inspection, and collection of corporate assets in the field. Field-workers accomplish the projects that you design and build using the ArcGIS Mobile application. The following PDF file documents the functionality of the ArcGIS Mobile application. It is recommended that you read through the application documentation to better understand how your field-workers will use the ArcGIS Mobile application to complete the projects that you build for them. You may also want to consider copying the PDF file to their Windows Mobile devices and/or printing the documentation for their reference when in the field.
The ArcGIS Mobile application Help is located in your ArcGIS Server instance directory (for example, C:\Inetpub\wwwroot\ArcGIS) under Manager\Help\arcgismobileapplication.pdf.
