An overview of scaling and moving a geodatabase
Release 9.3 |
![E-mail This Topic](../ahcommon/email_text.gif) ![Printable Version](../ahcommon/printable.gif) ![Give Us feedback](../ahcommon/feedback_text.gif) |
As discussed in the Types of geodatabases topic in the section "An overview of the geodatabase" in the help, there are different geodatabase options you can use depending on how many users you have, how much data you have, and what you need to do with your data.
Fortunately, as your needs change, you can scale your geodatabase to accommodate them. You might start with a file, personal, or ArcSDE geodatabase for SQL Server Express licensed through ArcGIS Desktop or ArcGIS Engine if there are only a few people using the data. As more people need access to the data and the amount of data you need to store and edit grows, you can move to an ArcSDE geodatabase for SQL Server Express licensed under ArcGIS Server Workgroup. When you outgrow Workgroup or if you need flexibility to configure things such as client connections and data storage, you can upgrade to an ArcSDE geodatabase licensed under ArcGIS Server Enterprise.
In most cases, once you have licensed and installed the necessary software, scaling a geodatabase involves copying the contents of one geodatabase and pasting it into another. There are some additional options if you want to move an entire ArcSDE geodatabase from one server to another. These options vary by ArcSDE type and database management system (DBMS). The following topics discuss ways to scale or move your geodatabase:
Migrating from one type of single-user geodatabase to anotherMigrating to an ArcSDE geodatabase licensed through ArcGIS Server WorkgroupMigrating to an ArcSDE geodatabase licensed through ArcGIS Server EnterpriseDetaching and attaching a geodatabase on a database serverExporting and importing ArcSDE geodatabases
NOTE: Scaling your geodatabase to accommodate increased demands for data is only one factor in a scalable GIS environment. To maintain performance, you also may need to scale your hardware and network resources.
