Log file tables in a geodatabase in PostgreSQL |
| Release 9.3 | ![]() ![]() ![]() |
Session-based log filesIf you alter your log file configuration to use session-based log files, you will see the sde_logfiles, sde_logfile_data, and sde_session<sde_id> tables in the geodatabase. These tables will be created in the schema of the user whose session caused the tables to be created. Although created, the sde_logfile_data table is not populated. The sde_logfiles and sde_logfile_data tables remain in the geodatabase, and rows are deleted from the sde_logfiles table when the connecting application disconnects. The sde_session<sde_id> table is truncated when the connecting application no longer needs the log file records (for ArcMap, this means there is no longer a selection set), and the table is dropped when the session disconnects.
Stand-alone logfilesIf you use stand-alone log files, for each selection set above the selection threshold made by a session, a new sde_logdata<sde_id>_<#> table is created for each layer. The names of these tables are stored in the logfile_data_table column of sde_logfiles table. The sde_logfiles and sde_logfile_data tables are also created per session, but the sde_logfile_data table isn't populated. Both of these tables are created in the schema of the user who caused them to be created.
The sde_logdata<sde_id> tables are truncated when the connecting session no longer needs the log files, and the tables are dropped when the session disconnects. Rows are deleted from the sde_logfiles table when the connecting application disconnects.
Pools of log filesThe sde_logfile_pool table is created and stored in the schema of the ArcSDE administrator when the geodatabase is created. If you use a pool of stand-alone or session-based log files owned by the ArcSDE administrator, this table will be used, plus sde_logpool_<table_id> tables will be created in the geodatabase. The number of sde_logpool_<table_id> tables created depends on the number you specify for the LOGFILEPOOLSIZE in the sde_server_config table. In the example below, LOGFILEPOOLSIZE is set to 10; therefore, sde_logpool tables 1 through 10 are created.
All the tables created for pools of log files are created in the ArcSDE administrator's schema.
NOTE: If MAXSTANDALONELOGS is set to a number greater than 0, and a user that has permissions to create database objects creates a selection set that exceeds the threshold for log files to be created, a stand-alone log file table will be created in that user's schema.
The following are the definitions for the tables that are used for ArcSDE log files. sde_logdata<sde_id>_<#>The sde_logdata<sde_id>_<#> table contains the list of business table records that are part of a stand-alone log file. <sde_id> denotes the session ID and <#> denotes the stand-alone log file sequence. This table is owned by the user who caused the table to be created.| Field name | Field type | Description |
| sde_row_id | integer | The row ID or shape ID of the business table row being logged; log files can log either row IDs, shape IDs, or user IDs. NOT NULL. |
| Field Name | Field Type | Description |
| sde_row_id | integer | The row ID or shape ID of the business table row being logged; log files can log either row IDs, shape IDs, or user IDs. Uniquely identifies a record and enables removal of duplicate <logfile_data_id,sde_row_id> values. NOT NULL. |
| logfile_data_id | integer | Identifies the log file to which the row ID belongs and is a reference to the log file metadata in the sde_logfiles table. NOT NULL. |
| table_id | integer | Identifies the log file pool table. Primary key. NOT NULL. |
| sde_id | integer | Identifies which ArcSDE connection is currently using the given log file pool table. The sde_id is a reference to the sde_id column of the sde_process_information table. If sde_id is NULL, it means this log file pool table is not currently in use. |
| logfile_name | character varying(255) | A unique user-defined (or application-defined) name for the log file. NOT NULL. |
| logfile_id | integer | Uniquely identifies the log file. Primary key. NOT NULL. |
| logfile_data_id | integer | Identifies the log file to which the row ID belongs. NOT NULL. |
| registration_id | integer | The registration ID of the business table for which IDs are being logged in this log file. NOT NULL. |
| flags | integer | A bit mask of values that indicate properties of the log file. NOT NULL. |
| session_tag | integer | A unique identifier for a connection's session, which allows a given ArcSDE connection to purge all temporary log files belonging to its session, for example. NOT NULL. |
| logfile_data_db | character varying(32) | The name of the database in which the table that's holding the IDs for this log file is stored. |
| logfile_data_owner | character varying(32) | The name of the owner of the table that's holding the IDs for this log file. |
| logfile_data_table | character varying(32) | The name of the table that is holding the IDs for this log file. This could be the traditional sde_logfile_data or a log pool table, a session table, or a stand-alone sde_logdata<sde_id>_<#> table. |
| column_name | character varying(32) | The name of the column in the business table that is being logged. Generally, this is the row ID or shape ID, but you can also specify an arbitrary integer column to be logged. |
| logfile_data_id | integer | Identifies the log file to which the row ID belongs and is a reference to the log file metadata in the sde_logfiles table NOT NULL |
| sde_row_id | integer | The row ID or shape ID of the business table row being logged; log files can log either row IDs, shape IDs, or user IDs NOT NULL |
