NOTE: None of these tables should be altered using Structured Query Language (SQL).
| Field name |
Field type |
Description |
| column_id |
integer |
The XML column's identifier and the table's primary key.
This value is assigned by ArcSDE at the time the XML column is created.
NOT NULL. |
| registration_id |
integer |
The identifier of the business table containing the XML column and foreign key to the table_registry system table.
NOT NULL. |
| column_name |
varchar(32) |
The name of the column in the business table that is the XML column.
NOT NULL. |
| index_id |
integer |
The identifier of the XPath index associated with the XML column (if one exists) and foreign key to the sde_xml_indexes table. |
| minimum_id |
integer |
The value of the initial number used in the business table's XML column to identify individual XML documents. |
| config_keyword |
varchar(32) |
The DBTUNE configuration keyword whose parameters determine how the XML document, XML XPath index tables, and text indexes created on those tables are defined in the database.
For more information on DBTUNE keywords and their parameters, see DBTUNE configuration keywords and DBTUNE configuration parameter name-configuration string pairs. |
| xflags |
integer |
A value indicating if the original documents in the XML document table are stored compressed or uncompressed.
By default, documents are compressed; compressed documents provide better performance.
NOT NULL. |
| Field name |
Field type |
Description |
| index_id |
integer |
The identifier of the XPath index and the table's primary key.
NOT NULL. |
| index_name |
varchar(32) |
The name of the XPath index.
For XPath indexes associated with an ArcIMS metadata service, the name is ims_xml#, where # is the identifier of the XML column in the sde_xml_columns table.
NOT NULL. |
| owner |
varchar(32) |
The database user who owns the XML column.
For ArcIMS metadata services, this is the user specified in the service's ArcXML configuration file.
NOT NULL. |
| index_type |
integer |
A value indicating the type of XPath index.
The value is 2 for the index type SE_XML_INDEX_DEFINITION and 1 for the index type SE_XML_INDEX_TEMPLATE. For XPath indexes associated with an ArcIMS metadata service, the default index type is SE_XML_INDEX_DEFINITION.
NOT NULL. |
| description |
varchar(64) |
Text identifying the XPath index.
If an index definition file is used to create the index, the index description can be specified at the top of the file. |
| Field name |
Field type |
Description |
| index_id |
integer |
The identifier of the XPath index associated with an XML column (if one exists) and foreign key to the sde_xml_indexes table.
NOT NULL. |
| tag_id |
integer |
The identifier of an XPath or tag.
NOT NULL. |
| tag_name |
varchar(1024) |
An absolute XPath identifying an XML element or attribute that may occur in an XML document.
For example, /metadata/mdDateSt identifies an XML element and /metadata/dataIdInfo/tpCat/TopicCatCd/@value identifies an XML attribute. These XPaths must not contain asterisks (*) to refer to a group of XML elements or attributes—each element or attribute is matched exactly using the XPaths specified in this table. Elements can't be named "*" in a valid XML document.
NOT NULL. |
| data_type |
integer |
A value indicating if the XML element or attribute is indexed as a number, varchar, or as text; a value of 1 indicates the content of the tag will be indexed as text, a 2 indicates the content of the tag is indexed as a number, and a 3 indicates the content of the tag is indexed as a varchar.
NOT NULL. |
| tag_alias |
integer |
A number that can be used to identify an XPath.
For example, the Z39.50 communication protocol uses numeric codes to refer to content that can be searched. This column is not used by the ArcIMS Z39.50 Connector. |
| description |
varchar(64) |
Text identifying the content that should be contained in the XML element or attribute. |
| is_excluded |
integer |
A value indicating whether the XML element is included in or excluded from the XPath index.
0 = The XPath is included.
1 = The XPath is excluded.
NOT NULL. |
