| DBMS |
Description |
| Oracle |
The ST_Geometry data type is one of the options for storing feature geometry in an ArcSDE geodatabase. It is included with ArcSDE for Oracle and is one of the feature storage options you have for Oracle. It is a high performance storage type provided as part of ArcSDE for Oracle that includes ISO- and OGC-compliant SQL access to geodatabase features. |
| IBM DB2 |
The DB2 Spatial Extender provided by IBM as part of the DB2 product is the only option used to store feature geometry in geodatabases in DB2. It was codeveloped by ESRI and IBM and is a high performance storage type that provides ISO- and OGC-compliant SQL access to geodatabase features. NOTE: There are some differences in SQL syntax between DB2 for z/OS and DB2 for Windows/Linux/UNIX. Consult the DB2 documentation for proper syntax for the DBMS version you are using.
| IBM Informix |
The Informix Spatial DataBlade provided by IBM as part of the Informix product is the only option used to store feature geometry in geodatabases in Informix. It was codeveloped by ESRI and IBM and is a high performance storage type that provides ISO- and OGC-compliant SQL access to geodatabase features. |
| PostgreSQL |
The ST_Geometry data type is the default for storing feature geometry in an ArcSDE geodatabase in PostgreSQL. As with the other DBMS implementations, the PostgreSQL implementation provides ISO- and OGC-compliant SQL access to geodatabase features. |
