NOTE: Moving data from one database to another can cause data types to remap.
When you create a feature class or table in ArcGIS, there are 11 different data types available for each column. These types are mapped to Access data types in the following table.
| ArcGIS data type |
Access data type |
Notes |
| OBJECTID |
Long Integer |
OBJECTID is an AutoNumber field. |
| SHORT INTEGER |
Integer |
| LONG INTEGER |
Long Integer |
| FLOAT |
Single |
| DOUBLE |
Double |
| TEXT |
Text |
| DATE |
Date/Time |
| BLOB |
OLE Object* |
| GUID |
Number |
| GEOMETRY |
OLE Object* |
| RASTER |
Memo |
Memo fields can store up to 65,536 characters. |
*Object linking and embedding (OLE) objects are objects created in other applications that are linked or embedded in Access. In this case, binary large object (BLOB) and GEOMETRY data types don't exist in Access, so the object is in ArcGIS and linked to the Access database.
When you create a feature class or table in ArcGIS, there are 11 different data types available for each column. These types are mapped to DB2 types in the following table.
| ArcGIS data type |
DB2 data type |
Notes |
| OBJECTID |
INTEGER(4) |
NOT NULL |
| SHORT INTEGER |
SMALLINT(2) |
| LONG INTEGER |
INTEGER(4) |
| FLOAT |
DECIMAL(31,8) |
| DOUBLE |
DECIMAL(31,8) |
| TEXT |
VARCHAR(n) |
| DATE |
TIMESTAMP |
| BLOB |
BLOB |
| GUID |
CHARACTER(38) |
| GEOMETRY |
ST_GEOMETRY |
ST_Geometry is a superclass. The actual data subtype created (such as ST_Multilinestring or ST_Point) depends on what type of feature class you create such as polygon, line, point, multipoint, and multipatch. |
| RASTER |
INTEGER(4) |
When you create a feature class or table in ArcGIS, there are 11 different data types available for each column. These types are mapped to Informix types in the following table.
| ArcGIS data type |
Informix data type |
Notes |
| OBJECTID |
INT(4) |
NOT NULL |
| SHORT INTEGER |
SMALLINT(2) |
| LONG INTEGER |
INT(4) |
| FLOAT |
DECIMAL(32) |
| DOUBLE |
DECIMAL(32) |
| TEXT |
VARCHAR(n) |
| DATE |
DATETIME |
| BLOB |
BLOB |
| GUID |
CHAR(8) |
| GEOMETRY |
ST_GEOMETRY |
| RASTER |
INT(4) |
When you create a feature class or table in ArcGIS, there are 11 different data types available for each column. These types are mapped to Oracle types in the following table.
| ArcGIS data type |
Oracle data type |
Notes |
| OBJECTID |
NUMBER(38) |
NOT NULL |
| SHORT INTEGER |
NUMBER(4) |
| LONG INTEGER |
NUMBER(38) |
| FLOAT |
NUMBER(38,8) |
| DOUBLE |
NUMBER(38,8) |
| TEXT |
NVARCHAR2(n) or VARCHAR2(n) |
This field will be NVARCHAR2 in the database only if your geodatabase is using Unicode storage; otherwise, VARCHAR2 is used. |
| DATE |
DATE |
| BLOB |
BLOB |
| GUID |
CHAR(38) |
| GEOMETRY |
ST_GEOMETRY*
NUMBER(38)
SDO_GEOMETRY |
Oracle data type depends on the geometry storage specified for the layer. |
| RASTER |
BLOB
LONG_RAW |
Oracle data type depends on the raster storage specified in the DBTUNE table. |
*ST_Geometry is a superclass. The actual data subtype created (such as ST_Multilinestring or ST_Point) depends on what type of feature class you create such as polygon, line, point, multipoint, and multipatch.
When you create a feature class or table in ArcGIS, there are 11 different data types available for each column. These types are mapped to PostgreSQL types in the following table.
| ArcGIS data type |
PostgreSQL data type |
Notes |
| OBJECTID |
INTEGER |
| SHORT INTEGER |
SMALLINT |
| LONG INTEGER |
INTEGER |
| FLOAT |
NUMERIC(38,8) |
| DOUBLE |
NUMERIC(38,8) |
| TEXT |
CHARACTER VARYING |
| DATE |
TIME WITHOUT TIME ZONE |
| BLOB |
BYTEA |
| GUID |
CHARACTER VARYING(38) |
| GEOMETRY |
ST_GEOMETRY*
GEOMETRY
Data type depends on the geometry storage specified for the layer. |
| RASTER |
INTEGER |
*ST_Geometry is a superclass. The actual data subtype created (such as ST_Multilinestring or ST_Point) depends on what type of feature class you create, whether polygon, line, point, multipoint, or multipatch.
When you create a feature class or table in ArcGIS, there are 11 different data types available for each column. These types are mapped to SQL Server types in the following table.
| ArcGIS data type |
SQL Server data type |
Notes |
| OBJECTID |
INT(4) |
NOT NULL |
| SHORT INTEGER |
SMALLINT(2) |
| LONG INTEGER |
INT(4) |
| FLOAT |
REAL |
| DOUBLE |
DOUBLE |
If scale is set to greater than 0 in ArcGIS, the SQL Server data type is NUMERIC. |
| TEXT |
NVARCHAR(n) or VARCHAR(n) |
The data type is NVARCHAR if your geodatabase stores Unicode text. With NVARCHAR, you can have up to 4000 characters. If you are not using Unicode, text fields are VARCHAR. For VARCHAR, you can have up to 8000 characters. If you create a field with a value larger than the maximum allowed for that data type, the field will be converted automatically to a BLOB type. |
| DATE |
DATETIME |
| BLOB |
IMAGE |
| GUID |
UNIQUEIDENTIFIER(16) |
| GEOMETRY |
IMAGE |
| RASTER |
IMAGE |
