Log file tables in a geodatabase in Oracle |
Release 9.3 |
NOTE: If MAXSTANDALONELOGS is set to a number greater than 0, and a user that has CREATE TABLE permissions creates a selection set that exceeds the threshold for log files to be created, a stand-alone log file table will be created in that user's schema.
The following are the definitions for the tables that are used for ArcSDE log files. SDE_LOGDATA<SDE_ID>_<#>The SDE_LOGDATA<SDE_ID>_<#> table contains the list of business table records that are part of a stand-alone log file. <SDE_ID> denotes the session ID and <#> denotes the stand-alone log file sequence. These tables are stored in the user's schema.Field name | Field type | Description |
SDE_ROW_ID | NUMBER(38) | The ROW ID or SHAPE ID of the business table row being logged; log files can log either ROW IDs or SHAPE IDs NOT NULL |
Field Name | Field Type | Description |
LOGFILE_DATA_ID | NUMBER(38) | Identifies the log file to which the ROW ID belongs and is a reference to the log file metadata in the SDE_LOGFILES table NOT NULL |
TABLE_ID | NUMBER(38) | Identifies the log file pool table. NOT NULL. |
SDE_ID | NUMBER(38) | Identifies which ArcSDE connection is currently using the given log file pool table. The SDE_ID is a reference to the SDE_ID column of the PROCESS_INFORMATION table. If SDE_ID is NULL, it means this log file pool table is not currently in use. |
LOGFILE_NAME | NVARCHAR2(256) | A unique user-defined (or application-defined) defined name for the log file NOT NULL |
LOGFILE_ID | NUMBER(38) | Uniquely identifies the log file NOT NULL |
LOGFILE_DATA_ID | NUMBER(38) | Identifies to which log file the ROW ID belongs NOT NULL |
REGISTRATION_ID | NUMBER(38) | The registration ID of the business table for which IDs are being logged in this log file NOT NULL |
FLAGS | NUMBER(38) | A bit mask of values that indicate properties of the log file NOT NULL |
SESSION_TAG | NUMBER(38) | A unique identifier for a connection's session, which allows a given ArcSDE connection to purge all temporary log files belonging to its session, for example NOT NULL |
LOGFILE_DATA_DB | NVARCHAR2(32) | The name of the database in which the table that's holding the IDs for this log file is stored |
LOGFILE_DATA_OWNER | NVARCHAR2(32) | The name of the owner of the table that's holding the IDs for this log file |
LOGFILE_DATA_TABLE | NVARCHAR2(98) | The name of the table that is holding the IDs for this log file; could be the traditional SDE_LOGFILE_DATA table or a log pool table, a session table, or a stand-alone SDE_LOGDATA<SDE_ID>_<#> table |
COLUMN_NAME | NVARCHAR2(32) | The name of the column in the business table that is being logged; generally, the ROW ID or SHAPE ID but can also specify an arbitrary integer column to be logged |
LOGFILE_DATA_ID | NUMBER(38) | Identifies to which log file the ROW ID belongs and is a reference to the log file metadata in the SDE_LOGFILES table NOT NULL |
LOGFILE_DATA_ID | NUMBER(38) | Identifies to which log file the ROW ID belongs and is a reference to the log file metadata in the SDE_LOGFILES table Primary key NOT NULL |
SDE_ROW_ID | NUMBER(38) | The ROW ID or SHAPE ID of the business table row being logged; log files can log either ROW IDs or SHAPE IDs Primary key NOT NULL |
