Managing multiple ArcSDE component installations on the same machine |
| Release 9.3 | ![]() ![]() ![]() |
NOTE: Geodatabases created with an ArcGIS Server Enterprise license on Windows only
It is possible to install more than one instance of ArcSDE for different database management systems on the same machine. Some ESRI products share the same administrator commands (for example, sdeservice, sdemon). To successfully run more than one ArcSDE component installation for different DBMSs on the same machine, follow the steps below. For information on installing multiple instances of the ArcSDE component for the same type of DBMS on the same machine, see Using multiple geodatabases within a DBMS.NOTE: Steps 1 and 2 above apply whenever administrator commands for ESRI products are run. If you do not change your System PATH, the administrator commands for the wrong product may be run.
