Oracle DEFAULTS keyword
| Release 9.3 |
As the name indicates, the settings under the DEFAULTS configuration keyword are used by default when you create tables, feature classes, raster datasets, and indexes. If you do not specify a different keyword when data is created in the geodatabase, or if you specify a keyword that is missing some necessary parameters, values from the DEFAULTS keyword are used.
You need to supply the information shown in brackets (<>) and uncomment the associated TABLESPACE lines by removing the # sign. The parameters grouped under the DEFAULTS keyword should be set to values that apply to most of the data in your geodatabase. If you do not uncomment the tablespace lines and provide values, the data will be stored in the default tablespace of the user creating the data.
##DEFAULTS
GEOMETRY_STORAGE "ST_GEOMETRY"
ATTRIBUTE_BINARY "BLOB"
RASTER_STORAGE "BLOB"
AUX_INDEX_COMPOSITE "PCTFREE 0 INITRANS 4
# TABLESPACE <RAS Table tablespace name>
NOLOGGING"
AUX_STORAGE "PCTFREE 0 INITRANS 4
# TABLESPACE <RAS Table tablespace name>"
A_INDEX_RASTER "PCTFREE 0 INITRANS 4
# TABLESPACE <ADDS Table default index tablespace name>
NOLOGGING"
A_INDEX_ROWID "PCTFREE 0 INITRANS 4
NOLOGGING"
A_INDEX_SHAPE "PCTFREE 0 INITRANS 4
#TABLESPACE <ADDS Table default index tablespace name>
NOLOGGING"
A_INDEX_STATEID "PCTFREE 0 INITRANS 4
NOLOGGING"
A_INDEX_USER "PCTFREE 0 INITRANS 4
NOLOGGING"
A_INDEX_XML "PCTFREE 0 INITRANS 4
NOLOGGING"
A_STORAGE "PCTFREE 0 INITRANS 4
# TABLESPACE <default ADDS table tablespace name>"
BLK_INDEX_COMPOSITE "PCTFREE 0 INITRANS 4
NOLOGGING"
BLK_STORAGE "PCTFREE 0 INITRANS 4
BND_INDEX_COMPOSITE "PCTFREE 0 INITRANS 4
NOLOGGING"
BND_INDEX_ID "PCTFREE 0 INITRANS 4
NOLOGGING"
BND_STORAGE "PCTFREE 0 INITRANS 4
B_INDEX_RASTER "PCTFREE 0 INITRANS 4
# TABLESPACE <default index tablespace name>
NOLOGGING"
B_INDEX_ROWID "PCTFREE 0 INITRANS 4
NOLOGGING"
B_INDEX_TO_DATE "PCTFREE 0 INITRANS 4
NOLOGGING"
B_INDEX_USER "PCTFREE 0 INITRANS 4
NOLOGGING"
B_INDEX_XML "PCTFREE 0 INITRANS 4
NOLOGGING"
B_STORAGE "PCTFREE 0 INITRANS 4
# TABLESPACE <default business table tablespace name>"
D_INDEX_DELETED_AT "PCTFREE 0 INITRANS 4
# TABLESPACE <DELETES table default index tablespace name>
NOLOGGING"
D_INDEX_STATE_ROWID "PCTFREE 0 INITRANS 4
NOLOGGING"
# TABLESPACE <default DELETES table tablespace name>"
RAS_INDEX_ID "PCTFREE 0 INITRANS 4
# TABLESPACE <RAS tablespace name>
NOLOGGING"
RAS_STORAGE "PCTFREE 0 INITRANS 4
# TABLESPACE <RAS tablespace name>"
S_INDEX_ALL "PCTFREE 0 INITRANS 4
NOLOGGING"
# TABLESPACE <default spatial index table tablespace name>"
ST_GEOM_LOB_STORAGE "STORE AS (
ENABLE STORAGE IN ROW CHUNK 8K RETENTION CACHE)"
UI_TEXT ""
ST_INDEX_LOCAL_PARTITION "FALSE"
XML_DOC_INDEX "PCTFREE 0 INITRANS 4 NOLOGGING
# TABLESPACE <XML tablespace name>"
XML_DOC_LOB_STORAGE "NOCACHE NOLOGGING CHUNK 4K PCTVERSION 5 DISABLE STORAGE IN ROW
# TABLESPACE <XML LOB tablespace name>"
XML_DOC_MODE "COMPRESSED"
XML_DOC_STORAGE "PCTFREE 0 INITRANS 4
XML_DOC_TEXT_TYPE "LONGRAW"
XML_DOC_VAL_LOB_STORAGE "NOCACHE NOLOGGING CHUNK 4K PCTVERSION 5 DISABLE STORAGE IN ROW
XML_IDX_INDEX_DOUBLE "PCTFREE 0 INITRANS 4
NOLOGGING"
XML_IDX_INDEX_ID "PCTFREE 0 INITRANS 4
NOLOGGING"
XML_IDX_INDEX_PK "PCTFREE 0 INITRANS 4
NOLOGGING"
XML_IDX_INDEX_TAG "PCTFREE 0 INITRANS 4
NOLOGGING"
XML_IDX_INDEX_TEXT ""
XML_IDX_STORAGE "PCTFREE 0 INITRANS 4"
XML_IDX_TEXT_TAG_STORAGE ""
XML_IDX_TEXT_UPDATE_MEMORY ""
XML_IDX_TEXT_UPDATE_METHOD "NONE"
UNICODE_STRING "TRUE"
END
