Exception code |
Exception text |
Description |
20001 |
SE_EXP_CTX_INIT |
An error has occurred initializing the extproc context handle. This is most likely due to a memory allocation error (Oracle only). |
20002 |
SE_EXP_CONVERT_SPREF_ERR |
Error converting spatial reference. |
20003 |
SE_EXP_OCI_DATATYPE_ERR |
Error converting geometry type (Oracle only). |
20004 |
SE_EXP_SHAPE_FROM_TEXT_ERR |
Error generating shape from text. |
20005 |
SE_EXP_NULL_LOB_LOCATOR |
The LOB locator is invalid (is null). |
20006 |
SE_EXP_TEXT_FROM_SHAPE_ERR |
Error generating text from shape. |
20007 |
SE_EXP_MEM_ALLOC_ERR |
Error allocating memory to well-known binary buffer. |
20008 |
SE_EXP_MAX_SHAPE_PTS_EXCEEDED |
The number of points specified for the shape exceeds the maximum allowed. |
20009 |
SE_EXP_NULL_SRID |
An invalid spatial reference ID value was specified for the primary shape. |
20010 |
SE_EXP_INVALID_RELATION_FUNCT |
Invalid spatial relation function specified. |
20011 |
SE_EXP_MAKE_SHAPE_ERR |
Error generating shape. |
20012 |
SE_EXP_MAKE_COORDREF_ERR |
Error changing the coordinate reference. |
20013 |
SE_EXP_SHAPE_SIZE_ERR |
Error getting well-known binary shape size. |
20014 |
SE_EXP_SHAPE_TO_WKB_ERR |
Error generating shape from well-known binary. |
20015 |
SE_EXP_SHAPE_FROM_BINARY_ERR |
Error generating shape from binary. |
20016 |
SE_EXP_SHAPE_TO_RECTANGLE_ERR |
Error generating rectangle from shape. |
20017 |
SE_EXP_INVALID_GOEM_OPER |
The specified spatial operator is invalid. |
20018 |
SE_EXP_INVALID_GEOM_OP_FUNCT |
The specified spatial operator function is invalid. |
20019 |
SE_EXP_RELATE_MASK_NULL |
The ST_Relate matrix is null. |
20020 |
ST_GEOM_MULTIPLE_SRIDS |
The ST_Geometry column being registered has more than one spatial reference ID (SRID) defined. All rows in the ST_Geometry column must have the same SRID (Oracle only). |
38999 |
SDE_FAILURE |
Unexpected error; unknown function was called. |
Exception code |
Exception text |
Description |
20600 |
SDE_SHAPE_TEXT_ERROR |
The shape text contains a syntax error. |
20601 |
SDE_INVALID_SRID |
The specified spatial reference ID does not exist in the database. |
20602 |
SDE_OUT_OF_MEMORY |
Not enough memory to complete operation. |
20603 |
SDE_INCOMPATIBLE_SREFS |
The specified spatial reference is not expected (is incompatible). |
20604 |
SDE_INVALID_BYTE_STREAM |
Invalid binary string was specified. |
20605 |
SDE_INVALID_GEOMETRY_TYPE |
The specified geometry type for the shape is invalid. |
20606 |
SDE_PARENTHESIS_MISMATCH |
Parentheses pairs don't match up; check for unclosed parentheses or that you specified the correct number of parentheses pairs for the shape type specified. For example, multipart polygons require an extra set of parentheses. |
20607 |
SDE_TOO_MANY_PARTS |
A single part shape type was specified with multiple parts. |
20608 |
SDE_TYPE_MISMATCH |
An unexpected shape type was specified. |
20609 |
SDE_SHAPE_TEXT_TOO_LONG |
String specified to define the shape exceeds the allocated buffer size. |
20610 |
SDE_INVALID_PARAM_VALUE |
The specified parameter value is invalid. |
20612 |
SDE_INVALID_GRID_SIZE |
The specified spatial index grid size is invalid (Oracle only). |
20613 |
SDE_GRID_SIZE_TOO_SMALL |
The specified spatial index grid size is too small (Oracle only). |
Exception code |
Exception text |
Description |
20800 |
SDE_INVALID_SHAPE |
An invalid shape was specified; cannot be verified. |
20801 |
SDE_INCOMPATIBLE_SHAPES |
The specified shapes are of incompatible types. |
20802 |
SDE_SHAPE_INTEGRITY_ERROR |
The shape's geometry is not complete. |
20803 |
SDE_TOO_MANY_POINTS |
The number of point coordinates provided is more than is allowed for the type of geometry. For example, if inserting or creating a point feature, you should only be specifying one set of coordinates. |
20804 |
SDE_ALL_SLIVERS |
Sliver factor caused all results to be slivers. |
20805 |
SDE_BUFFER_OUT_OF_BOUNDS |
Specified buffer falls outside the spatial bounds of the dataset. |
20806 |
SDE_INVALID_SYSTEM_UNITS |
Invalid x-, y-, z-, or m-units were specified. |
20807 |
SDE_COORD_OUT_OF_BOUNDS |
One or more of the coordinates provided falls outside the spatial bounds of the dataset. |
20808 |
SDE_INVALID_COORDSYS_ID |
The specified coordinate system ID is not found in the database. |
20809 |
SDE_INVALID_COORDSYS_DESC |
The coordinate system description provided does not match any descriptions in the database. |
20810 |
SDE_PROJECTION_ERROR |
Error projecting shape points. |
20811 |
SDE_POLY_SHELLS_OVERLAP |
Two donuts or two outer shells overlap. |
20812 |
SDE_TOO_FEW_POINTS |
The number of point coordinates provided is not sufficient for the type of geometry. For example, if inserting or creating a polygon feature, at least four coordinate sets (x,y; x,y,z; or x,y,z,m coordinates) must be specified. |
20813 |
SDE_INVALID_POLYGON_CLOSURE |
The defined coordinate points for the polygon do not create a closed polygon (i.e., the first and last coordinate points should be the same). |
20814 |
SDE_INVALID_OUTER_SHELL |
A polygon outer shell does not completely enclose all donuts for the part. |
20815 |
SDE_ZERO_AREA_POLYGON |
The definition provided for the polygon feature creates a polygon with no area. For example, if you define the polygon with three points, and the first and third points are the same, the polygon has no area. |
20816 |
SDE_POLYGON_HAS_VERTICAL_LINE |
The polygon shell contains a vertical line. |
20817 |
SDE_OUTER_SHELLS_OVERLAP |
One of the multipart areas contains overlapping parts. |
20818 |
SDE_SELF_INTERSECTING |
Valid shapes do not have self-intersecting lines; therefore, the shapes are invalid due to the presence of self-intersecting lines. |
20819 |
SDE_INVALID_NUM_MEASURES |
The number of measures specified in the binary is invalid. |
20820 |
SDE_INVALID_NUM_PARTS |
The number of parts specified in the binary is invalid. |
20821 |
SDE_INVALID_PART_OFFSET |
The specified part offset is invalid. |
20822 |
SDE_INVALID_PART_SEPARATOR |
The specified part separator is in the wrong position. |
20823 |
SDE_BINARY_TOO_SMALL |
Shape won't fit in supplied binary. |
20824 |
SDE_INVALID_ENTITY_TYPE |
The specified shape entity type is invalid. |
20825 |
SDE_INVALID_BYTE_ORDER |
The well-known binary shape byte order is invalid. |
20826 |
SDE_INVALID_PARTNUM |
Specified part doesn't exist in the shape. |
20827 |
SDE_NIL_SHAPE_NOT_ALLOWED |
A nil shape cannot be specified for a well-known binary. |
