using System;
using System.Collections.Generic;
using System.Text;
using ESRI.ArcGIS.esriSystem;
using ESRI.ArcGIS.Server;
namespace arcgisservice
class Program
static void Main(string[] args)
GISServerConnection connection = null;
IServerObjectAdmin3 soa = null;
try
connection = new GISServerConnection();
connection.Connect(args[0]);
catch (Exception e)
Console.WriteLine("Could not connect to server. Make sure this user is a member of the AGSADMIN group.");
Console.WriteLine(e.StackTrace);
usage();
try
soa = (IServerObjectAdmin3)connection.ServerObjectAdmin;
if (String.Compare(args[3], "stop") == 0)
soa.StopConfiguration(args[1], args[2]);
else if (String.Compare(args[3], "start") == 0)
soa.StartConfiguration(args[1], args[2]);
else
Console.WriteLine("No recognizable command. Choose from [stop | start].");
usage();
catch (Exception e)
Console.WriteLine("Error connecting to service. The service or service type does not exist. Check your case and spelling.");
usage();
static void usage()
Console.WriteLine("Usage: arcgisservice [serverName] [serviceName] [serviceType] [start | stop]");
Console.WriteLine(" Example: arcgisservice myServer myService MapServer stop");
Environment.Exit(-1);
