WMS Styled Layer Descriptor (SLD) samples
Release 9.3 E-mail This Topic Printable Version Give Us Feedback
The following SLD samples are available on the public server sampleserver1.arcgisonline.com. Their purpose is to help you understand how WMS services from ArcGIS Server work with external SLD resources.
Each sample has a corresponding SLD XML file accessible through the URL http://sampleserver1.arcgisonline.com/arcgis/wms/slds/<file_name>.xml, to mimic an external SLD xml resource from a client. Each sample also has a WMS GetMap request which requests a public ArcGIS Server WMS service (also on sampleserver1.arcgisoneline.com) to render the map using a style defined in the external SLD resource.
All SLD samples below are designed and created for a public ArcGIS Server WMS service called ESRI_StatesCitiesRivers_USA, which can be accessed through the URL http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer? To use the samples, you can either click the GetMap request link or copy the request string and open it in a browser.
To view the content of a sample SLD file, just directly access the XML through the provided URL. Alternatively, you are free to download any of the sample SLD XML files below, modify them, and expose them back again through a public URL so that you can request the ESRI_StatesCitiesRivers_USA WMS service to render the map using your own SLD style.
point_pointSymbolizer
point_propertyIsEqualTo
point_propertyIsNotEqualTo
point_propertyIsLike
point_not
point_bbox
point_within
polyline_lineSymbolizer
polygon_polygonSymbolizer
polygon_textSymbolizer
polygon_propertyIsEqualTo
polygon_propertyIsGreaterThan
polygon_propertyIsGreaterThanOrEqualTo
polygon_propertyIsLessThan
polygon_propertyIsLessThanOrEqualTo
polygon_multiple_rules
polygon_and
polygon_or
polygon_contains
polygon_crosses
polygon_disjoint
polygon_intersects
polygon_overlaps
Description: An SLD style that uses a "pointSymbolizer" to render features in a point layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_pointSymbolizer.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,1,2&STYLES=,,pointSymbolizer&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_pointSymbolizer.xml
GetMap response:
Description: An SLD style that uses a "propertyIsEqualTo" filter to render only a subset of all features in a point layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_propertyIsEqualTo.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,1,2&STYLES=,,propertyIsEqualTo&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_propertyIsEqualTo.xml
GetMap response:
Description: An SLD style that uses a "propertyIsNotEqualTo" filter to render only a subset of all features in a point layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_propertyIsNotEqualTo.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,1,2&STYLES=,,propertyIsNotEqualTo&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_propertyIsNotEqualTo.xml
GetMap response:
Description: An SLD style that uses a "propertyIsLike" filter to render only a subset of all features in a point layer. For example: Only render cities whose name starts with "San" or "Santa".
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_propertyIsLike.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,1,2&STYLES=,,propertyIsLike&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_propertyIsLike.xml
GetMap response:
point_not
Description: An SLD style that uses a "not" logic filter to negate another filter and render only a subset of all features in a point layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_not.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,1,2&STYLES=,,not&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_not.xml
GetMap response:
point_bbox
Description: An SLD style that uses a "bbox" spatial filter to render only features within a bounding box.
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_bbox.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,1,2&STYLES=,,bbox&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_bbox.xml
GetMap response:
point_within
Description: An SLD style that uses a "within" spatial filter to render only features within a polygon geometry
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_within.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,1,2&STYLES=,,within&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/point_within.xml
GetMap response:
Description: An SLD style that uses a "lineSymbolizer" to render features in a polyline layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polyline_lineSymbolizer.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,1&STYLES=,lineSymbolizer&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polyline_lineSymbolizer.xml
GetMap response:
Description: An SLD style that uses a "polygonSymbolizer" to render features in a polygon layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_polygonSymbolizer.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0&STYLES=polygonSymbolizer&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_polygonSymbolizer.xml
GetMap response:
Description: An SLD style that uses a "textSymbolizer" to add text to each feature in a polygon layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_textSymbolizer.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0&STYLES=textSymbolizer&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_textSymbolizer.xml
GetMap response:
Description: An SLD style that uses a "propertyIsEqualTo" filter to render only a subset of all features in a polygon layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_propertyIsEqualTo.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,0&STYLES=,propertyIsEqualTo&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_propertyIsEqualTo.xml
GetMap response:
Description: An SLD style that uses a "propertyIsGreaterThan" filter to render only a subset of all features in a polygon layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_propertyIsGreaterThan.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,0&STYLES=,propertyIsGreaterThan&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_propertyIsGreaterThan.xml
GetMap response:
Description: An SLD style that uses a "propertyIsGreaterThanOrEqualTo" filter to render only a subset of all features in a polygon layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_propertyIsGreaterThanOrEqualTo.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,0&STYLES=,propertyIsGreaterThanOrEqualTo&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_propertyIsGreaterThanOrEqualTo.xml
GetMap response:
Description: An SLD style that uses a "propertyIsLessThan" filter to render only a subset of all features in a polygon layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_propertyIsLessThan.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,0&STYLES=,propertyIsLessThan&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_propertyIsLessThan.xml
GetMap response:
Description: An SLD style that uses a "propertyIsLessThanOrEqualTo" filter to render only a subset of all features in a polygon layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_propertyIsLessThanOrEqualTo.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,0&STYLES=,propertyIsLessThanOrEqualTo&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_propertyIsLessThanOrEqualTo.xml
GetMap response:
Description: An SLD style that uses multiple rules to apply distinct symbology on subsets of features in a polygon layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_multiple_rules.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0&STYLES=multiple_rules&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_multiple_rules.xml
GetMap response:
polygon_and
Description: An SLD style that uses an "and" logic filter to combine two other filters together to render a subset of features in a polygon layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_and.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,0,1&STYLES=,and,&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_and.xml
GetMap response:
polygon_or
Description: An SLD style that uses an "or" logic filter to combine with another filter to render a subset of features in a polygon layer
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_or.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,0,1&STYLES=,or,&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_or.xml
GetMap response:
polygon_contains
Description: An SLD style that uses a "contains" spatial filter to render only polygon features that contain a specific point
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_contains.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,0,1,2&STYLES=,contains,,sf&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_contains.xml
GetMap response:
polygon_crosses
Description: An SLD style that uses a "crosses" spatial filter to render only polygon features that cross another feature
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_crosses.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,0,1&STYLES=,crosses,northPlatte&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_crosses.xml
GetMap response:
polygon_disjoint
Description: An SLD style that uses a "disjoint" spatial filter to render only polygon features that disjoint another feature
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_disjoint.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,0,1&STYLES=,disjoint,northPlatte&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_disjoint.xml
GetMap response:
polygon_intersects
Description: An SLD style that uses an "intersects" spatial filter to render only polygon features that intersect another feature
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_intersects.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,0,1&STYLES=,intersects,redRiver&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_intersects.xml
GetMap response:
polygon_overlaps
Description: An SLD style that uses an "overlaps" spatial filter to render only polygon features that overlap another feature
URL of SLD file: http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_overlaps.xml
GetMap request: http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?VERSION=1.3.0&REQUEST=GetMap&CRS=CRS:84&BBOX=-178.217598,18.924782,-66.969271,71.406235&WIDTH=765&HEIGHT=360&LAYERS=0,0&STYLES=,overlaps&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SLD=http://sampleserver1.arcgisonline.com/arcgis/wms/slds/polygon_overlaps.xml
GetMap response:
