Using the HTML Viewer toolbar expand/collapse all
expand/collapse item About the HTML Viewer toolbar
The HTML Viewer toolbar appears to the left of the map display area. It includes all of the tools you selected when designing your Web site as well as two buttons unique to the HTML Viewer: Toggle between Legend and LayerList, and Toggle Overview Map.
HTML Viewer toolbar
Toggle between Legend and LayerList: Switches back and forth between a legend with symbology and a layer list with visibility options.
Toggle Overview Map: Adds or removes the overview map from the map display area.
Zoom In: Zooms in to the area of the map that you click or drag a box around.
Zoom Out: Zooms out from the area of the map that you click or drag a box around.
Zoom to Full Extent: Zooms to the full extent of the map.
Zoom to Active Layer: Zooms to the full extent of the active layer.
Back to Last Extent: Zooms to the previous extent.
Pan: Pans the display in the direction that you drag the mouse pointer.
Pan to North, Pan to South, Pan to East, Pan to West: Pans the map in one direction - north, south, east, or west.
Identify: Displays attribute information for the feature that you clicked.
Query: Searches for features based on a query expression.
Search: Searches for features based on the information you enter.
Find: Finds map features with an attribute value matching a string that you type.
Measure: Measures distances on the map.
Set Units: Sets the units for measurements.
Buffer: Selects the features of one layer that are within the specified buffer distance of selected features of another layer.
Select by Rectangle: Selects the group of features contained by or in contact with a rectangle you draw on the map.
Select by Line/Polygon: Selects the group of features contained by or in contact with a line or polygon you draw on the map.
Clear Selection: Clears the selected set of features.
Locate Address: Locates a street address on the map.
Print: Prints the map to your default printer.
Search code: @html_toolbar
