Log file locations and names expand/collapse all
Related Topics
Interpreting Spatial Server log files
Dynamically start and stop full logging
Enabling full verbose logging
expand/collapse item About log file locations and names
Log files help keep track of what is happening on your site. As the Spatial Servers, Application Server, Monitor, and Tasker process requests, certain information is logged depending on the log level. This information is helpful for monitoring your site for performance and also to help troubleshoot issues when a problem arises.
The ArcIMS log files are found in various locations, depending on the type of log file. The following log files are always available.
Log file Description Location
Spatial Server log files See below for a detailed list of Spatial Server log files. Windows: <ArcGIS Installation Directory>\ArcIMS\Server\log
UNIX and Linux: $AIMSHOME/log
AppServerStatus.log Contains brief ArcIMS site startup, recycling information, notes about error conditions that have occurred, and administrative activities performed on ArcIMS site. More detailed information is available in the Application Server debug log files. Windows: <ArcGIS Installation Directory>\ArcIMS\AppServer
UNIX and Linux: $AIMSHOME/Middleware/Application_Server
RecyclingSummary.log Provides statistics on the most recent recycling event. The log file is present if you have ArcMap Server installed, or have set recycling on another server type. Windows: <ArcGIS Installation Directory>\ArcIMS\AppServer
MonitorStatus.log Lists the date and time Monitor was last started, records certain errors generated during the startup of the process, and records errors when ArcIMS is not authorized on the machine. Windows: <ArcGIS Installation Directory>\ArcIMS\Server\Monitor
UNIX and Linux: $AIMSHOME/Monitor
TaskerStatus.log Lists the date and time Tasker was last started and records certain errors generated during the startup of the process. Windows: <ArcGIS Installation Directory>\ArcIMS\AppServer\Tasker
UNIX and Linux: $AIMSHOME/Middleware/Tasker
The following log files are available when full verbose logging or dynamic logging is turned on.
AppServerDebug_<pid>.log The Application Server debug log contains detailed request and response notes, error and warning conditions, and other activities that occur within the Application Server. The <pid> value in the log file name represents a unique identifier. When a debug file reaches its maximum size limit, the old file is renamed to AppServerDebug_<pid>_0.log, and a new file is generated with the original name. Windows: <ArcGIS Installation Directory>\ArcIMS\AppServer\log
UNIX and Linux: $AIMSHOME/Middleware/Application_Server/log
Tasker_<pid>.log The Tasker debug log contains a log of the number of files deleted each time Tasker cleans files and directories. Windows: <ArcGIS Installation Directory>\ArcIMS\AppServer\Tasker\log
UNIX and Linux: $AIMSHOME/Middleware/Tasker/log
MonitorDebug_<pid>.log The Monitor debug log contains a summary of communications between the Monitor and the Application Server. Windows: <ArcGIS Installation Directory>\ArcIMS\Server\Monitor\log
UNIX and Linux: $AIMSHOME/Monitor/log
where
<pid> is the process ID for the Application Server, Monitor, or Tasker.
Over time, you may see many log files in their directories. Each time you restart ArcIMS, a new set of log files is generated. New log files are also generated during Spatial Server recycling or when a Spatial Server process is restarted for some reason.
Spatial Server log file naming conventions
When you look in the directories with Spatial Server log files, you will likely see many files, particularly if you have ArcMap Server installed. A new set of ArcMap Server log files is created each time ArcMap Server is recycled. The naming convention of the log files are as follows.
Administrative log files
The first set of files in your log file directory capture administrative information about the Spatial Server, such as initialization messages and 3rd-party messages.
<Server machine>_<Server ID number>_Container_<pid>.log Contains information about threads used by the ArcIMS Spatial Server process, including when initialization is completed for each server (Image, ArcMap, Query, Extract, Feature, Geocode, and Metadata).
<Server machine>_<Server ID number>_stderr_<pid>.log Contains error messages from third party applications used by the ArcIMS Spatial Server. This log rarely has entries.
<Server machine>_<Server ID number>_stdout_<pid>.log Contains informational messages from third party applications used by the ArcIMS Spatial Server. This log rarely has entries.
where
<Server machine> is the name of the machine the Spatial Server is running on.
<Server ID number> is a unique sequential number starting at 1.
<pid> is the process ID for the Spatial Server. This number is used throughout the log files for referencing the Spatial Server.
Component log files
In addition to the administrative log files, you will see one log file for each Spatial Server component. These files can be moved to a central machine if you have Spatial Servers running on several machines.
<Server machine>_<Server ID number>_ImageServer_<pid>.log Contains a detailed description of Image Services used by ArcIMS. This description includes thread initialization information, configuration file content, GET_IMAGE and GET_RASTER_INFO requests, responses, and response times.
<Server machine>_<Server ID number>_QueryServer_<pid>.log Contains information on thread initialization information, configuration file content, GET_FEATURES and GET_PROJECT requests, and response times. This log file is used with Image Services.
<Server machine>_<Server ID number>_FeatureServer_<pid>.log Contains information on thread initialization information, configuration file content, GET_FEATURES requests, and response times. This log file is used with Feature Services.
<Server machine>_<Server ID number>_GeocodeServer_<pid>.log Contains information on requests, the location of geocode styles, the match key name, the location to be matched, and time to perform the match. This log file is used with Image and Feature Services.
<Server machine>_<Server ID number>_ExtractServer_<pid>.log Contains information on thread initialization, configuration file content, GET_FEATURES requests, and response times. This log file is used with Image Services.
<Server machine>_<Server ID number>_MetadataServer_<pid>.log Contains a detailed description of Metadata Services used by ArcIMS. This description includes thread initialization information, metadata requests, responses, and response times.
<Server machine>_<Server ID number>_ImageServer_ArcMap_<pid>.log Contains a detailed description of ArcMap Image Services used by ArcIMS. This description includes thread initialization information, requests, and request times.
When you look in your Spatial Server log file directory, you will see a list of files similar to the following if you have one Spatial Server running. The Metadata service log file will only be present if you have started a Metadata Service. In this example, the machine name is "ESRI", the Spatial Server ID is "1", and the process ID for the Spatial Server is "1234".
esri_1_Container_1234.log
esri_1_stdout_1234.log
esri_1_stderr_1234.log
esri_1_ImageServer_1234.log
esri_1_QueryServer_1234.log
esri_1_GeocodeServer_1234.log
esri_1_FeatureServer_1234.log
esri_1_ExtractServer_1234.log
esri_1_MetadataServer_1234.log
ArcMap Server, by default, consists of two Spatial Servers used exclusively by ArcMap Services. For each Spatial Server hosting ArcMap Image Services, you will see the three administration log files plus an ArcMap Server component log file for a total of eight additional files. In your log file directory, you would see something similar to the following in addition to the log files previously described. In this example, the Spatial Server IDs are "2" and "3", and the process ID?s for the Spatial Servers are "5555" and "7777", respectively.
esri_2_Container_5555.log
esri_2_stdout_5555.log
esri_2_stderr_5555.log
esri_2_ImageServer_ArcMap_5555.log
esri_3_Container_7777.log
esri_3_stdout_7777.log
esri_3_stderr_7777.log
esri_3_ImageServer_ArcMap_7777.log
When you add additional Spatial Servers, a new set of log files is added for each Spatial Server. The log files can be identified by the machine name, unique Server ID, and process ID.
Search code: @log_name
