Checking site status using URL requests expand/collapse all
expand/collapse item About checking site status using URL requests
ArcIMS provides requests that allow you to check the status of your ArcIMS site. These requests return information about ArcIMS, such as the version number. When you check the status of your ArcIMS site using the Diagnostic Tool, you are sending a similar URL to the Servlet Connector and Application Server.
The following URL requests are available:
expand/collapse item How to check the site status using URL requests
expand/collapse item Checking site status using URL requests
  1. Open a browser.
  2. In the URL space, type the following:
    http://<server>/servlet/com.esri.esrimap.Esrimap?cmd=ConnectorPing
    or
    http://<server>/servlet/com.esri.esrimap.Esrimap?cmd=GetVersion
    or
    http://<server>/servlet/com.esri.esrimap.Esrimap?cmd=Ping
    Where <server> is the name and domain of your Web server.
    If the Servlet Connector is working properly during ConnectorPing, your browser will display:
    "IMS vX
    Build_Number=xxx.yyyy
    Version=X
    Test successful"
    If the Application Server is working properly during GetVersion, your browser will display:
    "Build Number=xxx.yyyy
    Version=X"
    If the Servlet Connector is enabled during Ping, your browser will display "IMS vX".
Search code: @stability_status
