Display Quality
Release 8 E-mail This Topic Printable Version Give Us Feedback
The Display Quality tab is used to specify various display options in ArcPad that control the display quality as well as the display performance. Greeking can be activated or deactivated for point, polyline, polygon, and multi point features.
Greeking is a method for simplified drawing of features using fewer pixels, resulting in faster drawing performance. Greeking thresholds are used to control this simplified drawing. Features that require fewer pixels to draw than the specified threshold are drawn using simplified symbology. Further information on greeking thresholds is available in the ArcPad Studio Help.
Point Greeking
When checked, ArcPad uses greeking thresholds to draw point features. When unchecked, ArcPad draws the features using the symbology described in the layer definition file (.apl).
The default is checked.
Polyline Greeking
When checked, ArcPad uses greeking thresholds to draw polyline features. When unchecked, ArcPad draws the features using the symbology described in the layer definition file (.apl).
Polygon Greeking
When checked, ArcPad uses greeking thresholds to draw polygon features. When unchecked, ArcPad draws the features using the symbology described in the layer definition file (.apl).
Multi Point Greeking
When checked, ArcPad uses greeking thresholds to draw multi point features. When unchecked, ArcPad draws the features using the symbology described in the layer definition file (.apl).
