The StreetMap toolbar |
Release 8 |
The StreetMap toolbar is automatically displayed after a StreetMap layer is loaded into the ArcPad map, and is automatically closed after the StreetMap layer is removed from the ArcPad map.
The StreetMap toolbar consists of the following buttons:
Reverse geocodes a location
Converts the current location to a stop.
Finds a route between stop points while preserving the order of the stops.
Opens the Edit Stops dialog box, which allows you to change the order of stops, temporarily disable stops, and delete stops.
Displays or hides driving directions for the current route.
Opens the StreetMap Preferences dialog box.
Opens a dialog box for finding an address, city, or latitudelongitude coordinate.
Finds a location using the current GPS position.
Removes the location selection from the map.
Converts the current location to a barrier.
Converts the current location to a pushpin.
Finds a route between stop points by reordering intermediate locations.
Removes a calculated route from the map.
Opens the Edit Stops dialog box, which allows you to manage the order of stops, temporarily disable stops, and delete stops.
Opens the Edit Barriers dialog box, which allows you to edit properties of barriers, temporarily disable barriers, and delete barriers.
Opens the Edit Pushpins dialog box, which allows you to edit properties of pushpins, disable pushpins, and delete pushpins.
