Picture |
Release 8 |
The Picture tab is used to display the photo, or digital image file, that is associated with the selected feature. The file name of the digital image is stored in a field associated with the selected feature’s shapefile. A feature can have multiple photos associated with it, but each photo file name needs to be stored in a unique field.
The associated photo can be changed by either using the camera button to open the camera tool for capturing a new photo or by using the folder button to choose an existing photo on your device.
Displays the photo, which is referenced by the file name stored in the field selected in the field dropdown list.
This is a display-only field.
Choose the field in which to store the file name of the photo associated with the selected feature.
ArcPad automatically populates the Field drop-down list with field names that appear to be suitable for storing photo file names. To do this, ArcPad looks for any text field in the shapefile’s dBASE table that has a name containing the words photo, image, or picture. The text field also must to have a minimum length of 20 characters.
Tap to rotate the image 90
degrees to the left. The rotated image is stored in the image file.
Processing image files requires considerable free memory to perform the computations. You need to ensure that there is sufficient free memory on your device for ArcPad to perform the image rotation.
Tap to rotate the image 90 degrees
to the right. The rotated image is stored in the image file.
Tap to open the Camera tool to
capture a new photo, using the camera specified on the Camera tab of the ArcPad
Options dialog box. The new photo will be stored on your device and displayed in the
picture field. The image file name for the new photo will be stored in the field
selected in the Field drop-down list.
Tap to navigate to and select
