GPS
Release 8 E-mail This Topic Printable Version Give Us Feedback
The GPS tab is used to specify the protocol, communication, and other settings of your GPS receiver.
Protocol
Choose the protocol of your GPS receiver’s output: NMEA 0183, Earthmate, PLGR, SiRF, or TSIP.
The default is NMEA 0183.
Port
Choose the COM port that your GPS receiver is connected to on your device.
The default is COM1.
Baud
Choose the baud rate of your GPS receiver’s output.
The default is 4800.
Advanced Serial Port Parameters
Tap to open the Advanced Serial Port Parameters dialog box to specify additional communication settings for the serial port used to connect your GPS receiver. For most GPS receivers, it should not be necessary to specify these additional serial communication settings.
The advanced serial port parameters are described in the next section.
Find GPS
Tap to search for a connected GPS if you do not know which port on your device your GPS is connected to. You need to make sure that your GPS is connected and turned on (if appropriate) so the Find GPS tool can detect your GPS. The Port and Baud dropdown lists will be updated as the Find GPS tool searches for a connected GPS. Once a GPS has been detected you will be prompted to choose the GPS and use the corresponding settings.
Automatically Activate
When checked, the GPS is automatically activated whenever an existing ArcPad map file (.apm) with a defined projection is opened.
The default is unchecked.
Show GPS Activity in System Tray
When checked, the ArcPad icon displayed in the system tray flashes to indicate that the GPS receiver is active.
The default is checked.
Automatically Pan View
When checked, ArcPad automatically pans the map to keep the GPS position centered when the GPS is active.
Log
When checked, the raw data output by your GPS receiver is logged to the GPS log file in the My Documents\My ArcPad folder. The default name for the GPS log file is gps.log. Double-tapping Log opens the Save As dialog box for you to specify a different log file. This allows you to create multiple log files.
The contents of any existing GPS log file will be cleared. The Log check box must be checked before activating the GPS for the GPS log file to be used by ArcPad. Checking or unchecking the Log check box has no effect while the GPS is activated.
A GPS log file is useful for troubleshooting GPS issues, as it shows exactly what data ArcPad has received from the GPS.
