Geography |
Release 8 |
The Geography tab displays the geographic extent of the layer. In addition, for shapefiles, the code page of the table and the number of features in the layer are displayed along with an indication of whether the shapefile has a spatial index.
Displays the number of features in the shapefile or ArcPad AXF layer.
This is a display-only field. This information is only displayed for shapefile and AXF layers.
Displays the code page specified in the DBF table of the shapefile.
This is a display-only field. This information is only displayed for shapefile layers
Displays the code page used by ArcPad for the table of the shapefile. If the code page is specified in the DBF table, the code page in use is the same as the DBF code page. If the code page is not specified in the DBF table, the code page in use is determined as described in the “Locales and code pages” section of this reference guide.
This is a display-only field. This information is only displayed for shapefile layers.
Displayed if the shapefile contains a spatial index-that is, .sbn and .sbx files.
Displays the minimum x-coordinate of the layer’s extent in map projection units.
Displays the maximum x-coordinate of the layer’s extent in map projection units.
Displays the minimum y-coordinate of the layer’s extent in map projection units.
Displays the maximum y-coordinate of the layer’s extent in map projection units.
Displays the width of the layer’s extent in map projection units.
Displays the height of the layer’s extent in map projection units.
