Line Style |
Release 8 |
The Line Style tab is used to specify the default display settings for line symbols in a line layer. All lines in the layer have the same symbol. The fields on the Line Style tab are only available if no symbology has been defined in the ArcPad layer file, or if no symbol has been specified on the Styles tab of the line layer’s Symbol Properties dialog box. Tap Set To Default Line Style to delete the existing symbology settings and specify the default symbol settings for the line layer.
Choose the style of the line symbols: Solid, Dash, Dot, Dash dot, or Dash dot dot.
The default is Solid.
Type or use the arrow keys to choose the width of the line symbols. Valid widths range from 0 to 10.
The default is 1.
Tap the button to choose the color of the line symbols.
The default color is randomly selected by ArcPad.
Tap the button to delete the existing symbology settings and specify the default symbol settings for the line layer. Tapping the button activates all the fields on the Line Style tab.
