Polygon Style |
Release 8 |
The Polygon Style tab is used to specify the default display settings for polygon symbols in a line layer. All polygons in the layer have the same symbol. The fields on the Polygon Style tab are only available if no symbology has been defined in the ArcPad layer file or if no symbol has been selected on the Styles tab of the polygon layer’s Symbol Properties dialog box. Tap Set To Default Fill Style to delete the existing symbology settings and specify the default symbol settings for the polygon layer.
Choose the outline style of the polygon symbols: Solid, Dash, Dot, Dash dot, or Dash dot dot.
The default is Solid.
Type or use the arrow keys to choose the outline width of the polygon symbols.
The default is 1. Valid widths range from 0 to 10.
Tap the button to choose the outline color of the polygon symbols.
The default is black.
Tap the button to choose the fill color of the polygon symbols.
The default color is randomly selected by ArcPad.
When checked, polygon symbols are filled with the specified Fill Color. When unchecked, polygon symbols are not filled with any color.
The default is checked.
Tap the button to delete the existing symbology settings and specify the default symbol settings for the polygon layer. Tapping the button activates all the fields on the Polygon Style tab.
