Select default datum transformation |
| Release 8 |
Select the Datum and Associated Datums to display a list of all the possible transformations between these two datums. This information is extracted from ArcPad’s projection engine. If no transformation has been selected as the default, then the first transformation displayed is used by ArcPad. The default transformation has a check in the Default Transformation column’s checkboxes.
