ArcPad Check In |
| Release 8 |
ArcPad Check In tool allows you to check in the edits made in an ArcPad AXF file back into the geodatabase from which the data was checked out.
The following window appears when you open the ArcPad Check In tool:
Choose the AXF you wish to Check In, by using the folder button to navigate to the ArcPad AXF file. Enter the password (if one was defined at check out) and specify individual feature classes if required.
The results of the check in process are shown in a dialog box.
