Preparing your data for ArcPad |
| Release 8 |
ArcPad is a mapping tool for working with your GIS data in the field. Field GIS tasks are often quite different from the GIS tasks performed in the office, and so too are the computers used in these different environments. Desktop computers usually have fast CPUs, large amounts of RAM and disk space, and large display monitors. In contrast, field computers have relatively slow CPUs and limited RAM and storage capacity. Furthermore, the field work environment ranges from working in bright sunlight to rain to subzero snow conditions, compared to the constant temperature and lighting conditions of the office environment. Consequently, you need to consider all of these factors before preparing your GIS data for use in the field with ArcPad.
Answers to the following questions will determine how you need to prepare your data for optimum use in the field:
This is an important issue. The artificial light and large monitors used in the office environment enable the use of a wide range of colors and symbols, whereas only a limited number of colors and symbols provide sufficient contrast when used in the field with small computer screens and strong sunlight.
Although ArcPad supports most of the symbology available with ArcGIS, it may not always be appropriate for field conditions to use the complex symbology supported by ArcGIS and ArcPad. In many cases simple, high-contrast symbols using primary colors are more effective in the field than detailed symbols using a wide spectrum of colors.
There are a number of different operations that you may need to perform to prepare your data for use in the field with ArcPad, including:
The ArcPad Data Manager for ArcGIS provides some of the tools for preparing data for use with ArcPad. Additional tools for tasks such as projecting data are included with ArcGIS Desktop.
In summary, it is essential to always bear in mind that field computers, tasks, and conditions are very different to computers, tasks, and conditions in the office. Therefore, what works in the office environment may often not be effective in a field environment.
Data not supported by the ArcPad Data Manager
The following data types are not currently supported by the ArcPad Data Manager:
