Overview of editing stops, barriers, and pushpins
Release 8 E-mail This Topic Printable Version Give Us Feedback
The Edit Stops dialog box has many editing options. You can change the order of your stops (e.g., make your departure location your arrival location and vice versa or switch your second stop with your third stop), remove stops temporarily from a route, delete stops, zoom to a stop on your map, generate a route, edit titles, add comments, and create an optimized route.
Tip
Disabling a stop: To disable a stop, tap the Edit Stops button, uncheck the stop that you want to disable, and tap ok.
Tip
Entering comments: You may choose to enter comments that will appear with the labels for stops on the map. To do this, tap the Location Properties button on the Edit Stops dialog box, type or copy and paste text into the Comment text box, then tap ok.
