Overview of creating stops, barriers, and pushpins |
| Release 8 |
The Create Stop button allows you to create a stop, barrier, or pushpin from a location that you found.
A stop is a location on the map that will be included on your route as a place to stop. A barrier is a location on a map that you want to be avoided when you create your route. A pushpin is a placeholder on a map that you can later convert to a stop or barrier if desired.
