The StreetMap toolbar |
| Release 8 |
The StreetMap toolbar is automatically displayed after a StreetMap layer is loaded into the ArcPad map, and is automatically closed after the StreetMap layer is removed from the ArcPad map.
Switch to Streetmap toolbar by selecting the StreetMap icon fromt he toolbar selector. The StreetMap toolbar consists of the following buttons:
Reverse geocodes a location
Convert Location to
StopConverts the current location to a stop.
Create Route from StopsFinds a route between stop points while preserving the order of the stops.
Edit StopsOpens the Edit Stops dialog box, which allows you to change the order of stops, temporarily disable stops, and delete stops.
Driving DirectionsDisplays or hides driving directions for the current route.
StreetMap PreferencesOpens the StreetMap Preferences dialog box.
Find Address or LocationOpens a dialog box for finding an address, city, or Point of Interest.
Find Location from GPS
PositionFinds a location using the current GPS position.
Find by Latitude and LongitudeFinds a location using the latitude and longitude coordinates.
Unselect LocationRemoves the location selection from the map.
Convert Location to
Convert Location to
BarrierConverts the current location to a barrier.
Convert Location to
PushpinConverts the current location to a pushpin.
Create Optimized RouteFinds an optimised route between stop points by reordering intermediate locations.
Clear RouteRemoves a calculated route from the map.
Edit StopsOpens the Edit Stops dialog box, which allows you to manage the order of stops, temporarily disable stops, and delete stops.
Edit BarriersOpens the Edit Barriers dialog box, which allows you to edit properties of barriers, temporarily disable barriers, and delete barriers.
Edit PushpinsOpens the Edit Pushpins dialog box, which allows you to edit properties of pushpins, disable pushpins, and delete pushpins.
