NMEA 0183 sentences recognized by ArcPad |
| Release 8 |
ArcPad supports a number of protocols for communicating with GPS receivers, one of which is the NMEA 0183 version 2.0 standard protocol defined by the National Marine Electronics Association. The NMEA 0183 standard definition is available from http://www.nmea.org.
The NMEA 0183 standard defines sentences that are used to transmit data. These sentences consist of printable ASCII text (plus carriage return and line feed). Each sentence consists of the following data sequence:
The NMEA 0183 standard allows individual manufacturers to define proprietary sentence formats. These sentences start with $P, then a 3-letter manufacturer ID, followed by data from the manufacturer that follows the general format of the standard sentences.
A sample NMEA 0183 sentence for the GPS fix data might be as follows:
$GPGGA,121505,4807.038,N,01131.324,E,1,08,0.9,133.4,M,46.9,M, , *42
where
The NMEA 0183 version 3.0 standard adds the following additional values for the $GPGGA fix quality, which ArcPad recognizes:
ArcPad recognizes the following NMEA 0183 version 2.0 or higher sentences:
| Sentence | Description |
| $GPGGA | GPS fix data |
| $GPGLL | Geographic position, latitude and longitude |
| $GPGSA | GPS Dilution of Precision (DOP) and active satellites |
| $GPGSV | GPS satellites in view |
| $GPRMC | Recommend minimum specific GPS/TRANSIT data |
| $GPRRE | Range residual error |
| $GPVTG | Track made good and ground speed |
| $GPZDA | Time and date |
| $PGRME | Estimated error information (Garmin Proprietary) |
| $PGRMT | Sensor Information (Garmin Proprietary) |
| $PMGNVER | GPS hardware and software version numbers (Magellan Proprietary) |
| $PASHR,POS | Position information (Ashtech Proprietary) |
| $PASHR,SAT | GPS satellite tracking status information (Ashtech Proprietary) |
| $PRWIRID | Version Information (Rockwell Proprietary) |
| $PRWIZCH | Channel Status (Rockwell Proprietary) |
| $SDDPT | Depth, in meters |
| $SDMTW | Water Temperature, in degrees Celcius |
Most GPS receivers output a limited number of NMEA 0183 sentences. ArcPad uses data from a number of NMEA 0183 sentences to display all of the information in the GPS Position Window as well as to populate the fields associated with the GPS Tracklog. When information is not displayed in the GPS Position Window it is usually the result of ArcPad not receiving the required NMEA 0183 sentence from the GPS receiver.
