The Go To tool can be used to select a navigation destination. Simply activate the
tool and tap anywhere on the map to select your destination.
Tap the arrow below the Identify button to display the drop-down list.
Tap Go To.
The Go To button is displayed on the Browse toolbar and is depressed to
indicate that the tool is active.
Tap the map to select a navigation destination.
The destination is displayed with a Mark label.
Use the GPS Position Window to view the distance (DST) and bearing (BRG) from
your current GPS position to your selected destination
Tip
Activating the GPS: It is not necessary to activate the
GPS before selecting a navigation destination. However, the GPS does need to
be activated in order to open the GPS Position Window and view the distance
and bearing to the destination.
Tip
Clearing the selected destination: To clear the selected
destination and remove the destination Mark label, tap the Clear Selected
tool
located on the
drop-down list below the Find Features button on the Browse toolbar. The
Mark label is displayed when a destination has been selected.
Refer to section,
Activating GPS, for help on activating the
GPS.
