Overview of adding layers |
| Release 8 |
You can display geographic information on a map as layers. Each layer represents a particular type of feature, such as streams, lakes, highways, or light posts. A layer does not store the actual geographic data; instead, it references the data contained in shapefiles, ArcPad AXF files, images, photo layers, graphics layers, StreetMap layers, or ArcIMS services.
The exceptions to this are StreetMap and graphics layers. These layers are automatically projected, on-the-fly, to the projection of the current ArcPad map.
When you select an .apm file from within the add layers dialog, you only add the layers from that .apm to your existing map. All other detail contained in the .apm is not loaded. For example, if your .apm contains bookmarks, these will not be added to your existing map.
