Overview of moving features |
| Release 8 |
To move a feature, you must first select it using one of the Select tools. With the Select and Select at GPS Position tools you can move the feature by dragging it. In order to move a point feature or vertex to a specific x, y coordinate or to the current GPS position, you must use the Select & Vertex Editing tool. Once changes have been made, you must commit the changes before they are saved. These steps eliminate the possibility of accidentally moving features in the field.
You can move features and vertices in three different ways:
Dragging is the easiest way to move a feature. Use this method when you have a general idea of where you want to move the feature. You can drag point, line, or polygon features.
You can type in new x,y coordinates or use the current GPS position coordinates when you want to move a point feature or line and polygon vertices to a precise location.
