Using Offsets to move a vertex
Release 8 E-mail This Topic Printable Version Give Us Feedback
  1. Tap the Select & Vertex Editing button.
  2. Select the polygon—or line— feature.
  3. Tap and hold within the blue vertex square to display the Move To menu.
  4. Tap Move To. The point/vertex dialog box is displayed.
  5. Tap the Offset page.
  6. Tap the Tripod button to set the reference point from the incoming GPS coordinates.
  7. Capture the bearing, distance, and, optionally, inclination values using your rangefinder.
  8. Tap OK on the Point/Vertex dialog box. Your vertex is moved to the new position.
    Tip
    Using Radial Traverse to move a vertex: You can move the selected vertex using Radial Traverse and the 1 or 2 Point Offset capabiltity in the Point/Vertex dialog box. Set one reference point or two reference points before selecting your vertex. Setting two reference points is only required for 2 point offsets such as Distance–Distance or Bearing– Bearing.
