Creating a line feature using the incoming GPS coordinates involves the following
steps:
- Select a line layer for editing via the Start/Stop Editing tool or the Table of
Contents.
- Activate the GPS.
- Tap the Polyline button to start capturing a line feature.
- Tap the Add GPS Vertex button to capture a single vertex, or tap the Add GPS
Vertices Continuously button to capture streaming vertices.
- Tap the Proceed button on the Command bar to complete the capture of the line
feature.
- Type in attributes for the new line feature.
Tip
Enabling GPS position averaging for vertices: GPS position averaging
for vertices is enabled in the Capture page of the GPS Preferences dialog box. You can
also specify the number of GPS positions for ArcPad to average.
Tip
Changing the streaming vertices position and distance intervals: By
default, the Add GPS Vertices Continuously mode captures a vertex each time ArcPad
receives a coordinate from the GPS. This may be too frequent and result in the capture
of unnecessary vertices. You can increase the streaming vertices position and distance
intervals in the Capture page of the GPS Preferences dialog box.
Tip
Creating GPS point features while capturing a polyline feature: The
GPS Point button will be enabled—if a point layer is active for editing—even while the
Polyline button is active and a line feature is in the process of being captured. While
capturing a polyline, you can tap the GPS Point button to capture a point feature
without having to first end the capture of the line feature. You will need to pause
streaming GPS data capture if it is active.
Tip
Pausing streaming GPS data capture: ArcPad continuously captures
vertices in a streaming mode when the Add GPS Vertices Continuously tool is active. Tap
the Add GPS Vertices Continuously button to pause or stop capturing vertices. Tap the
button again to resume capturing vertices.
