Using simple offsets to create new polyline and polygon features |
| Release 8 |
A simple offset is performed on a polyline or polygon and uses a specified offset distance. The offset distance can be based on an existing feature or other criteria such as distance from a the current GPS position.
Using a simple offset, you could, for example, map a line feature that is a given distance away from an existing line feature. You would then specify whether the new feature is left or right of the captured line.
A red box around the Offset Polyline/Polygon button indicates that it is active.
The Poly Offset dialog box is displayed.
As you add vertices to your new line or polygon, a red line at the offset distance will be displayed. This is where your new feature will be created.
The Feature Properties dialog box is displayed.
