Selecting a Mobile Device |
| Release 8 |
Mobile GIS involves a variety of tasks that are performed under varying environments and conditions. No two mobile GIS applications are the same, and different people have different preferences. For example, one person may be comfortable with entering text using a pen (or stylus) and character recognition software, while another person using the same application may prefer to use a physical keyboard. Similarly, one person may be comfortable with working with map data on a quarter-VGA (Video Graphics Adapter) screen (240 x 320 pixels), while another person may prefer a larger screen.
Selecting a suitable device for mobile GIS involves a process to determine which criteria are essential, “nice to have”, or not required. There is no perfect device for mobile GIS since many criteria are mutually exclusive. For example, it is not possible to have a device with a large screen and at the same time is compact enough to fit in your pocket—unless, of course, you have large pockets!
The following factors should be considered when selecting a device that best meets the needs and requirements of your mobile GIS application.
ArcPad runs on Windows Vista, XP and Windows Mobile devices. The first factor to consider is whether the mobile GIS device needs to run Windows Mobile or a PC version of Windows.
The advantages of Windows Mobile devices are:
The disadvantages of Windows Mobile devices are:
For many mobile GIS tasks a tablet PC or ultra mobile PC running Windows Vista or XP Tablet PC Edition may be a better choice than a Windows Mobile device. This is especially true if you require a larger screen and/or need to run additional software that does not support Windows Mobile. There are a number of hardware vendors that manufacture tablet PCs and ultra mobile PCs suitable for mobile GIS.
Your budget for each Windows Mobile device will help dictate which factors are essential. For example, ruggedized Windows Mobile devices are at least double the cost of standard Windows Mobile devices. When considering cost it is essential to consider the total cost of the mobile GIS task, including labor and replacement costs. Labor accounts for the major portion of mobile GIS costs, and therefore it is more cost effective in the long run to purchase robust, ruggedized devices, which last longer, resulting in less downtime from damaged and broken devices.
How large or small does the mobile device need to be? Ruggedized devices are usually bulkier and heavier than nonruggedized devices. The size of the device will dictate the screen size and whether the device has a physical keyboard.
Do you need a ruggedized mobile device? Ruggedized devices cost more to purchase but are more cost effective in the long run as discussed above.
How large or small does the screen need to be? Some people are comfortable using a small screen, while others prefer a larger screen. Most Windows Mobile devices have quarter-VGA screens (240 x 320 pixels), while Windows XP Tablet PCs have full-VGA (640 x 480 pixels) or larger screens.
Do you need a color screen display? Some applications do not require color displays, but most GIS data requires color to distinguish the various features and details on a map. This is especially true when using image data. Some of the ruggedized mobile devices are only available with grayscale displays.
If a color screen is a requirement, then it is essential that the display be readable in sunlight since mobile GIS tasks are usually performed outdoors. It is strongly recommended that you test any potential mobile device outdoors, in both direct sunlight and shade, before purchasing the device. Most Windows Mobile devices available today use reflective thin film transistor (TFT) screen technology, which is readable in direct sunlight.
How much data and what type of data do you need to store and use on your Windows Mobile device? It is recommended that you store your data on a storage card, or built-in storage, and not in RAM to keep as much RAM free for processing as possible. This also ensures that data is not lost if the battery is drained on the Windows Mobile device. It is also recommended that the Windows Mobile device have at least 64 MB of RAM and preferably more, if available.
As of this writing, the maximum capacity of commonly available and affordable storage cards is as follows:
| Storage Media | Maximum Capacity |
| Compact Flash (CF) | 64 GB for flash memory |
| Secured Digital (SD) | 4 GB for flash memory |
| SD High Capacity (SDHC) | 32 GB for flash memory |
| MiniSD | 2 GB for flash memory |
| MiniSDHC | 8 GB for flash memory |
| MicroSD | 8 GB for flash memory |
| MicroSDHC | 16 GB for flash memory |
Do you need a GPS for your mobile GIS task? If yes, do you need a GPS that is integrated with the mobile device? Integrated GPS receivers are easier to use, especially for the novice user. And integrated GPS receivers do not require any cumbersome cables for connecting the GPS to the mobile device—although an increasing number of GPS receivers are Bluetooth enabled, which eliminates the need for cables.
Does your mobile GIS task require a digital camera for taking photographs in the field? If yes, do you need a camera that is integrated with the mobile device? The biggest advantage of an integrated camera is that the image files are automatically stored on the same device as the mobile GIS data, resulting in easier and better integration of data. Unfortunately, integrated digital cameras are currently of inferior quality compared to standalone digital cameras, especially in terms of image resolution, optical zoom, and minimum light needed for taking a photograph. However, it is quite possible that an integrated camera may meet the requirements for your mobile GIS task.
Does your mobile GIS task require wireless connectivity? If yes, then it is recommended that you select a mobile device that has the required wireless connectivity integrated with the device.
There are a variety of wireless options available, each for a different purpose.
Bluetooth is designed for eliminating cables by wirelessly connecting mobile devices and accessories, using serial communications. Bluetooth is ideal for connecting a mobile device to a GPS receiver, laser range finder, or bar code scanner. Bluetooth is also useful for setting up a synchronization partnership between a Windows Mobile device and a desktop PC. It is important to note that Bluetooth implementation is not consistant across all manufacturers. If you need to connect multiple Bluetooth devices simultaneously you should ensure that you choose a mobile device that supports multiple Bluetooth connections.
WiFi (using either the 802.11b or 802.11g protocols) is useful for wirelessly connecting your mobile device to a local area network, or LAN. Connecting to a LAN is useful for accessing an ArcIMS web service, downloading or uploading data, as well as for setting up a synchronization partnership between a Windows Mobile device and a desktop PC.
Wide area networks, or WANs, are used for similar purposes as LANs, however the wireless technology for connecting to WANs have a longer range than the technology for connecting to LANs. The wireless protocols for connecting to WANs include GPRS, CDMA, EV-DO, UMTS/WCDMA, and EDGE.
What accessories do you need to use for your mobile GIS tasks? Your Windows Mobile device should have at least one serial port, or be Bluetooth enabled, for connecting GPS receivers and other serial input devices. Your Windows Mobile device should also have at least one expansion slot for a storage card—for example, CompactFlash or Secure Digital. Multiple expansion slots are useful when you need to use a storage card and accessory, such as a CompactFlash GPS receiver, simultaneously.
There are a variety of accessories available for CompactFlash and Secure Digital expansion slots. These accessories include flash memory, hard drives, GPS receivers, landline and wireless modems, digital phone cards, wired (Ethernet) and wireless local area network (LAN) cards (802.11b, 802.11g) Bluetooth cards, digital cameras, VGA cards, bar code scanners, and serial I/O cards.
It is highly recommended that you test potential Windows Mobile devices under similar conditions to those expected to be encountered when performing your mobile GIS tasks to ensure that the device meets your requirements. A color display may look bright and crisp under artificial office lighting but may be almost black when viewed in direct sunlight.
