Supported mobile devices |
| Release 8 |
ArcPad 8.0 supports the following Windows operating systems: Windows Vista, XP, and Windows Mobile. ArcPad does not support specific Windows Mobile devices, but instead supports specific Windows Mobile versions and processor chips. ArcPad should run on any Windows Mobile device that use a supported processor chip, and meets the minimum requirements for memory and scripting.
ArcPad is designed to run on any Windows Mobile device that meets the following minimum system requirements:
ArcPad supports Windows Mobile 5 or higher. ArcPad supports the Pocket PC and Pocket PC Phone Edition form factors—it does not support the Smartphone form factor.
Windows Mobile devices are built using a variety of processors, or CPU chips. Unlike desktop PCs where processor chips are compatible—for example, Intel® and AMD chips—processor chips used for Windows Mobile devices are not compatible and require that software be compiled specifically for the particular processor chip
ArcPad 8.0 only supports ARM-based CPU chips for Windows Mobile devices. ARM-based CPU chips include, but are not limited to, chips made by Intel (StrongARM and XScale®), Samsung™, Texas Instruments®, and Atmel®.
ArcPad requires a Windows Mobile device with at least 64 MB of RAM, and preferably more RAM if available.
The amount of free RAM required to install and run ArcPad depends on what sort of data will be used. Running ArcPad could require 20 MB or more of free RAM, especially if you are using compressed images in formats such as MrSID® and JPEG2000.
ArcPad can be customized using ArcPad Studio and scripting languages, such as VBScript and JScript. The corresponding scripting runtime library file must be installed on the device before running scripts. The JScript runtime library is already installed on most devices, while ArcPad automatically installs the VBScript runtime library when installing ArcPad. Customization of ArcPad is disabled when running ArcPad on a device that does not have the required scripting runtime library installed.
