Which files are included with FME?
If you install FME from the CD:
If you install FME from the CD, Safe Software automatically installs grid shift files for the following datum transformations:
Adding support for NAD83 <-> NAD27 Datum Shifts: When you install FME, one of the installation panels determines which NAD83 <-> NAD27 datum shifts will take precedence in FME. If you choose "Yes" FME will give precedence to the Canadian method in areas near the Canada-U.S. border. If you choose "No" FME will give precedence to the U.S. (NADCON) method in areas near the Canada-U.S. border.
NOTE: You can always change the precedence of these files later; for example, if you work with both Canadian and U.S. data. See Maintaining Grid Shift Files.
If you download FME from Safe Software's website or ftp site:
If you download and install FME, Safe Software provides grid shift files for the following datum transformations:
If your translation is failing or producing warnings because of missing grid shift files, you can install many of them using the Grid Shift File Installer available on the Datum Transformations and Grid Shift Files page on our website. This installer runs automatically if you install FME from CD.
Which files do you have to obtain separately?
Safe Software cannot provide grid shift files for the transformations listed below. In these cases, is it necessary to contact the appropriate jurisdiction to obtain the required files.
For detailed information on any of these files, select Tools > Browse Coordinate Systems, and press the F1 key.
Which OSTN shift files does FME include?
These text files will be included in the FME Reproject directory when you install FME from CD.
If you installed a beta or downloaded version of FME, you can add these files with the Grid Shift File Installer available on the Datum Transformations and Grid Shift Files page on our website.
USE Data Transformation Approximations
For more information on individual grid shift files, see USE Data Transformation Approximations.
