Choosing globe cache properties
Release 9.3 E-mail This Topic Printable Version Give Us Feedback
There are two steps to making a globe cache:
  1. Set cache properties.
  2. Create tiles.
This topic is about setting the cache properties. See Creating globe cache tiles for more about creating the tiles.
Accessing cache properties
When you view a globe service's properties in ArcCatalog, you will see a Caching tab. This is where you set the properties for your cache. You should make sure these options are correct before you begin creating tiles.
Note: The Caching tab for globe services is not available in Manager.
How to access cache properties in ArcCatalog
  1. Click the GIS Servers node in the Catalog tree.
  2. If necessary, make an administrative connection to your GIS server.
  3. Expand your GIS server and find the globe service whose caching properties you want to modify.
  4. Start the service if it is not already started.
  5. Right-click the service and click Service Properties.
  6. Click the Caching tab.
When you've finished setting the cache properties, click the Create Tiles button to start creating tiles. You can also return to this dialog box later and click Update Tiles to create more tiles or update existing ones.
Options on the Caching tab
The Caching tab contains the following globe caching options:
The server cache directory
Here you can change the default server cache directory that was selected when you created the globe service. To learn more about the server cache directory, see How globe caches work.
Creating tiles on demand
Tiles are always created when users navigate the globe, so the option to create tiles on demand is always enabled. For elevation layers, you cannot rely on users navigating the globe to create the cache; you must create the full cache using the globe cache generation tools.
Allowing clients to cache tiles locally
Finally, you have the option to allow clients to cache tiles locally. When users navigate your globe service, by default, the tiles are stored on their local machines. This can improve performance if they tend to navigate the same areas. However, once you update your globe cache their tiles will be outdated and they will explicitly need to clear their local caches before they can see the changes. If you will be updating your globe cache frequently, consider not allowing users to cache tiles locally.
