Starting, stopping, and removing services expand/collapse all
Related Topics
Changing and refreshing services
expand/collapse item About starting, stopping, and removing services
As part of your site management, you can start, stop, and remove services. Note that starting and stopping a service is not the same as refreshing it. If you change the content of your configuration file, you must refresh the service for the changes to take effect. When you stop and restart a service, the information in memory is not refreshed.
You can remove a service permanently if it is no longer needed. However, it is important to verify that no Web applications are using the service before you remove it.
Configuration files and their corresponding services are separate entities; therefore, you can remove a service without deleting the configuration file. As long as you do not manually delete the configuration file, it will always be available to you to recreate the same service or to create a different service.
expand/collapse item How to start, stop, and remove services
expand/collapse item Starting and stopping a service in Administrator
  1. In the left panel, click Services.
  2. In the right panel, in the Service Name column, click the name of a service you wish to start or stop.
  3. Click Start Start button or Stop Stop button in the Administrator toolbar.
The current status of the service is shown in the Status column.
expand/collapse item Removing a service from Administrator
  1. Click Services in the left panel.
  2. Click a service in the right panel.
  3. Click the Remove Service button Remove Service button in the Administrator toolbar.
  4. Click Yes to confirm removal.
The service is removed from the list of services. You can make your change permanent by clicking Save Configuration in the toolbar.
expand/collapse item Starting, stopping, and removing a service from Service Administrator
  1. Click the Manage Services tab.
  2. Check a service to select it.
    Check multiple services to provide the same action on more than one service at a time.
  3. Click Start to start the checked service(s).
  4. Click Stop to stop the checked service(s).
  5. Click Delete to delete the checked service(s).
    A message box appears warning you that you are about to delete a service. Click OK to proceed.
  6. You can make your change permanent by clicking Save Startup File.
Search code: @admin_start_service
