Changing and refreshing services expand/collapse all
Related Topics
Publishing an ArcIMS service
expand/collapse item About changing and refreshing services
After you have published an ArcIMS service, you can change some of the service properties. You must refresh your services whenever you change one of the properties or when you change the content in your configuration file. When a service is started, the content from the configuration file is read into memory. When you refresh the service, the contents are re-read into memory. After refreshing, your changes are reflected the next time the service is accessed. The changes will not be reflected on those client machines already accessing the service.
Note: refreshing a service is not the same as stopping and starting a service. When you stop and restart a service, the information in memory is not refreshed.
If you change the configuration file corresponding to a Feature Service, you must rebuild your Web site for your changes to be reflected. This is not necessary with Image or ArcMap Image services.
expand/collapse item How to change and refresh services
expand/collapse item Changing properties using Administrator
  1. In the left panel, click Services.
  2. In the right panel, click the service with properties you want to change.
  3. Click the Properties button Properties button in the Administrator toolbar.
  4. In the Service Properties dialog box, change properties as desired. You can change all properties except the name of the service. For details on the properties, see Publishing an ArcIMS service.
  5. In the Service Properties dialog, click OK.
  6. If you want to save your changes for your site configuration, click Save Configuration.
expand/collapse item Refreshing a service in Administrator
  2. In the right panel, in the Service Name column, click the name of a service you wish to refresh.
  3. Click the Refresh Service button Refresh Service button in the Administrator toolbar.
expand/collapse item Changing and refreshing properties using Service Administrator
  1. Click the Manage Services tab.
  2. Click the name of a service.
    The service properties options appear.
  3. Verify that the correct service is selected in the Settings for dropdown list.
  4. Click Browse and navigate to the appropriate configuration file.
  5. Click Open on the Choose file dialog box.
    The path to the configuration file appears as the Upload File Path.
  6. Change service settings as necessary.
  7. When finished changing settings, click Update.
  8. If the Save Startup File page appears, click yes or no for saving the Startup File.
ArcIMS notifies you that your service has been updated.
Search code: @admin_change_service
