Using images as symbols expand/collapse all
Related Topics
Drawing features using one symbol
Drawing features using graduated and unique symbols
Setting the scale dependency of symbols and renderers
Adding renderers and symbols
expand/collapse item About using images as symbols
If you are using one symbol for features in a point or polygon layer, you can use an image as your symbol. When you use an image, you do not need to choose a color or set outline properties; those settings are unavailable on the Symbols tab. For point layers, you still need to set the symbol size.
Because you will be publishing your map as a service, the images must be stored in a directory recognized by your Web server. This is either a directory under the Web server's root directory or a virtual directory that you created. The URL path to your image will look something like this: http ://<hostname>/<virtual directory path to image>. For example, assume your images are located in a directory called /arcims/myimages. If you have created a virtual directory pointing to this location named "images", the URL would be http://<hostname>/images.
If you do not specify a URL path to a folder that is recognized by your Web server, the symbols will not display when used in a service.
The recommended image size is 16 x 16 pixels or smaller. A larger image will draw at its full size on the map but will be cropped to approximately 16 x 16 pixels in the legend.
expand/collapse item How to create image symbols
expand/collapse item Adding images as symbols
  1. Click a point or polygon layer in the legend to make it active.
  2. Click the Layer Properties button Layer Properties on the Author toolbar to open the Layer Properties dialog box.
  3. Click the Symbols tab.
    One Symbol is selected by default.
  4. Click the Style dropdown arrow, and click Image.
  5. For point layers, click the Size arrows to change the symbol size, or type a value in the Size text box.
  6. Click the Browse button.
  7. Navigate to an image, click it, then click Open.
  8. Type the URL path to the image.
  9. Click OK to apply your changes and to close the Layer Properties dialog box.
expand/collapse item Troubleshooting image symbols
Images display in Author but not in the service
Check that you have specified the correct URL, and the directory you pointed to is a virtual directory.
Images no longer display after moving the service to a new machine
The URL is likely incorrect. You must edit the map configuration file and update the URL to match the new Web server's name.
Search code: @author_image_symbols
