esriadmin.properties reference for Site Administrator expand/collapse all
Related Topics
Configuring ArcIMS ports
expand/collapse item About esriadmin.properties
The esriadmin.properties file specifies default settings for Service Administrator. You only need to update this file if you need to change the Application Server or port number references. If you make modifications to this file, you must restart your Web server and servlet engine.
You can also change these properties using the Application Server Information dialog of the ArcIMS Configuration step in the post installation.
The following properties can be changed:
appserver_host=ARCIMSHOST
appserver_port=5300
Search code: @ref_esriadmin
