You can add one source dataset file, or specify multiple files to include all at once.
Select Add Dataset from the Source Data menu on the menu bar.
Specify the format and dataset filename. See Choosing from the Formats List.
Specify settings and coordinate system (if applicable), and press OK.
The log window will display processing information, and the dataset will appear in the source area of your workspace.
Tips:
If you want to add more source datasets that are in the same format as the existing source dataset in your workspace, follow the instructions in Merging Similar Datasets.
To extend the input of your workspace to include multiple source datasets that are in a different format than your existing source dataset:
Specify the format.
Enter a dataset filename.
To select multiple datasets,
click
. Type directly in the Directory field (you can use wildcards
to include all files of a specific format), or click Add Folder button
to browse for a specific directory name. Click the Subfolders box to also
include all subfolders below that directory. If you know that files are
the same schema, check the Identical Schemas box (this can have an effect
on overall processing time if you have many datasets).
Specify settings and the coordinate system (if applicable).
Press OK.
The log pane will display processing information, and the dataset will appear in the source area of your workspace.
