| Change a Note |
Feedback
E-mail this topic
Print this topic
Once you’ve created a note, you may want to alter its appearance, or change its popup content or title.
In many cases you'll want to change the note's symbol from the default. To do so, with the note selected, use the controls in the Appearance tab's Symbols and Location groups to modify the graphic properties of the symbol. An alternative to the Appearance tab is to right-click the note in the Contents window or on the map when you see its title. In the context menu that appears in both cases, select Symbol and choose a symbol from the gallery that appears.
Learn more about selecting and changing symbols.
You can Move or Replace the geometry of a Point, Line, or Area note by using the Edit tools.
Alternatively you can change an existing point note’s geometry by right-clicking it in the Contents window or on the map when you see its title. In the context menu that appears in both cases, select Properties... and then in the Note Properties dialog's Note Location section you can update the location.
Learn more about moving or replacing note geometries
To change the popup content of a Note, select the note and use the Popup Content button in the Popup group of the Tools tab. This will display the Popup window in editing mode.
Learn more about editing note popup content
Learn more about HTML for notes and other map content
Turn off popup content from appearing on a Note, select the note and uncheck the Use Popup checkbox in the Popup group of the Tools tab. The popup content will no longer appear for that note until Use Popup is checked back on.
