ArcGIS Server Banner
Schematic datasets in a geodatabase in Informix
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note:This topic was updated for 9.3.1.
NOTE: Requires Schematics extension
Schematic datasets are similar to feature datasets but they contain a collection of schematic diagram classes and schematic element classes (which are the schematic equivalent of feature classes). They are used to graphically visualize and manipulate network data.
A schematic dataset is always associated with a schematic project. When you create a schematic dataset in ArcCatalog, an associated schematic project is automatically created. A schematic project contains the graphic parameters and display rules for the schematic diagrams generated and stored in the schematic dataset.
Schematic datasets in ArcCatalog
The following is an example of a schematic dataset, schematic folders, and the schematic diagrams they contain in ArcCatalog:
Schematic dataset in ArcCatalog
Top of page
Schematic datasets in an Informix DBMS
The following tables are used to store information on schematic datasets.
sch_dataset
Contains one record for each schematic dataset. The id field in this table is used to identify the assosiated element and diagram tables.
Field name Field type Description
id Int Unique identifier of the schematic dataset
Not null
major Int Release number of the dataset version; not used at this time
Not null
minor Int Minor release number of the dataset version; not used at this time
Not null
bugfix Int Patch or service pack number of the dataset version; not used at this time
Not null
dbname Varchar(32) Name of the database in which the schematic dataset is stored
owner Varchar(32) The user who created the schematic dataset
name Varchar(128) The name of the schematic dataset
Not null
extclsid Varchar(38) Not currently in use
spatialref Varchar(1024) Default spatial reference used when creating new diagrams
blobs Blob Stores the default parameters for the dataset, such as the default node symbol, text separator, and character
sch_release
The sch_release table is not currently in use.
major Int Release number of the system tables; not used at this time
Not null
minor Int Minor release number of the system tables; not used at this time
Not null
bugfix Int Patch or service pack number of the system tables; not used at this time
Not null
sch_uniqueid
The sch_uniqueid table stores the unique identifier of a diagram type.
id Int The unique identifier used when creating new diagram types for the object class
Not null
dummy Int Not in use at this time
sch<id>_clsentry
Stores the associations between the diagram types and the element types in a schematic dataset
Field Name Field Type Description
id Int Uniquely identifies the relationship between a diagram type and element type
Not null
diagramclassid Int Foreign key to the id field in the sch<id>_diaclass table
Not null
elementclassid Int Foreign key to the id field in the sch<id>_eltclass table
Not null
sch<id>_datasrc
Contains a list of all the data sources accessed by the schematic dataset
id Int Uniquely identifies a data source
Not null
name Varchar(255) Name of the data source
Not null
clsid Varchar(38) Class id of the data source component
Not null
label Varchar(255) Not currently in use
connection Blob Parameters of the connection; used to persist and restore the connection
Not null
sch<id>_diaclass
Tracks all the diagram types present in a schematic dataset
id Int Uniquely identifies a diagram type
Not null
objectclassid Int Foreign key to the id field in the sch_uniqueid table
Not null
creationname Varchar(255) Name of the diagram class when the table is created
Not null
name Varchar(255) Current name of the diagram class (if it was changed from the original name)
Not null
parentid Int Id of the parent diagram class entry
Not null
datasourceid Int Foreign key to the id field of sch<id>_datasrc
builderclsid Varchar(38) Class id for the schema builder (custom query, network dataset, or standard)
linkerclsid Varchar(38) Component managing feature to element relationship method
algorithmclsid Varchar(38) Class id of the algorithm that is automatically applied to diagrams of this type
blobs Blob Stores all the attribute and symbology information
sch<id>_eltclass
Maintains a list of all the element types for each dataset
id Int Uniquely identifies an element type
Not null
objectclassid Int Foreign key to id in gdb_objectclasses table
Not null
creationname Varchar(255) Name of the element class when the table is created
Not null
name Varchar(255) Current name of the element class (if it changed)
Not null
parentid Int Id of the parent element class entry
elementtype Int Value specifying the type of element (node, link, etc.)
relationclsid Varchar(38) Relationship to a feature class
associateddsid Int Data source id of related feature class
associatedocid Int Id of the related feature classes from the gdb_objectclasses table
datasourceid Int Foreign key to the ID field in the sch<id>_datasrc table
blobs Blob Stores attribute and symbology
sch<id>_folder
Maintains a list of all the folders created in a dataset
id Int Unique identifier for the folder
Not null
name Varchar(255) Name of the folder
Not null
pfid Int Id of the parent folder if nested
Not null
xml Blob Stores the metadata of the folder
sch<id>a_<element_type_name>
Tracks the associations between an element and a feature
id Int Uniquely identifies the association between an element and a feature
Not null
schematicid Int Unique id for an element
Not null
datasourceid Int Foreign key to the id field in the sch<id>_datasrc table
ucid Int Class id of the related feature
uoid Int Object id of the related feature
usid Int Subtype id of the related feature
ueid Int Enabled id of the related feature
sch<id>d_<diagram_type_name>
Stores a list of all diagrams created using a particular diagram type (the one indicated by the <diagram_type_name>)
Not null
folderid Int Foreign key to the sch<id>_folder table
Not null
diagramclassid Int Foreign key to sch<id>_diaclass table's objectclassid field
Not null
lastupdate Datetime Date and time of last user update
Not null
version Varchar(255) If generated from versioned data, lists which version
creationdate Datetime Date and time diagram was created
creator Varchar(100) Name of the user that created the diagram
updatedby Varchar(100) Name of the user that last updated the diagram
spatialref Char(1024) Spatial coordinates
blobs Blob Stores the current positioning of all elements in the diagram
sch<id>e_<element_type_name>
Stores a list of all the elements created using an element type
Element types define the attributes and symbology of an element.
Not null
diagramclassid Int Foregn key to the sch<id>_diaclass table's objectclass id field
Not null
diagramobjectid Int Foreign key to the sch<id>d_<diagram_type_name> table
Not null
schematicid Varchar(128) Uniquely identifies an element; consists of diagramobjectid, diagramclassid, datasourceid, ucid, uoid, and usid
Not null
isinitial Int Indicates whether this element was part of the initial creation list
Not null
isdisplayed Int Indicates whether this element is currently displayed
Not null
relationobjectid Int Object id of related feature in relationship
relationclassid Int Class id of related feature in relationship
datasourceid Int Foreign key to sch<id>_datasrc table
ucid Int Class id of corresponding feature
uoid Int Object id of corresponding feature
usid Int Subtype id of corresponding feature
ueid Int Enabled value of corresponding feature
subtype Int Subtype of feature
propertyset Blob Holds attribute information
initialx Decimal(32,20) X positon of element when created
initialy Decimal(32,20) Y position of element when created
sch<id>r_<diagram_type_name>
Stores a list of all the relationship rules for a diagram type
id Int Uniquely identifies relationship rule
Not null
ordernumber Int Indicates in which order rules will be run
Not null
active Int Indicates whether or not the rule is active
Not null
clsid Varchar(38) Class id of the rule
Not null
propertyset Blob Property page values
Click the following link to see an example of schematic dataset system tables showing implicit links. Implicit links are denoted with the dashed lines.
Informix schematic dataset diagram
Schematic datasets in XML
Exporting schematic datasets to XML is not presently supported.
Top of page
See Also
  • Feature datasets in a geodatabase in Informix
