| Parameter name |
Description |
Values |
Notes |
| A_INDEX_ROWID |
Adds table object ID column index storage definition |
See your DB2 documentation for CREATE INDEX parameters. |
| A_INDEX_SHAPE |
Adds table spatial column index storage definition |
Does not apply to DB2 for z/OS |
| A_INDEX_STATEID |
Adds table sde_state_id column index storage definition |
| A_INDEX_USER |
Adds table index storage definition |
| A_STORAGE |
Adds table storage definition |
See your DB2 documentation for CREATE TABLE parameters. |
| AUX_STORAGE |
Raster AUX table storage definition |
| B_INDEX_ROWID |
Business table object ID column index and raster rowid index R<N>_SDE_ROWID_UK storage definition |
| B_INDEX_SHAPE |
Business table spatial column index storage definition |
| B_INDEX_TO_DATE |
Storage parameter info for creating the index R<registration_id>_sde_todate, which is used when updating the history table during an archive operation |
| B_INDEX_USER |
Business table user index storage definition |
| B_RUNSTATS |
Default value for RUNSTATS |
YES(default for DB2 on Linux, UNIX, and Windows) or NO (default for DB2 z/OS) |
| B_STORAGE |
Business table and raster attribute table storage definition |
| BLK_BLOB_OPTION |
Storage configuration properties of BLOB columns in the raster BLK table |
LOGGED NOT COMPACT (default for DB2 on Linux, UNIX, and Windows)
or
LOGGED COMPACT
or
NOT LOGGED COMPACT
or
NOT LOGGED NOT COMPACT |
The default value for this parameter in DB2 for z/OS is blank, and it should remain blank.
For DB2 for Linux, UNIX, or Windows, set to NOT LOGGED COMPACT. Setting this parameter to any other value can take up a lot more table space when loading raster data. |
| BLK_INDEX_COMPOSITE |
Raster BLK table composite column index storage definition |
| BLK_STORAGE |
Raster BLK table storage definition |
| BLOB_OPTION |
Storage configuration properties of the BLOB column |
or
LOGGED COMPACT
or
NOT LOGGED COMPACT
or
The default value for this parameter in DB2 for z/OS is blank, and it should remain blank. |
| BLOB_SIZE |
Size of BLOB column |
> 0 and < 2G
1M
If BLOB_OPTION is set to LOGGED, BLOB size cannot be larger than 1G. (DB2 recommends logged BLOB columns not be larger than 10M.) |
| BND_STORAGE |
Raster BND table storage definition |
| CLOB_OPTION |
Storage configuration properties of the CLOB column |
or
LOGGED COMPACT
or
NOT LOGGED COMPACT
or
| CLOB_SIZE |
Size of CLOB column |
> 0 and < 2G
32K
If CLOB_OPTION is set to LOGGED, CLOB column cannot be larger than 1G. (DB2 recommends logged LOB columns not be larger than 10M.) |
| COMMENT |
Line used for comments |
Can place any comment up to 2048 characters |
| D_INDEX_DELETED_AT |
Deletes table sde_deleted_at column index storage definition |
| D_INDEX_ STATE_ROWID |
Deletes table sde_states_id and sde_deletes_row_id column index storage definition |
| D_STORAGE |
Deletes table storage definition |
| LD_INDEX_DATA_ID |
SDE_logfile_data storage definition |
| LD_INDEX_ROWID |
SDE_logfile_data table SDE_ROWID column index storage definition |
| LD_STORAGE |
SDE_logfile_data table storage definition |
| LF_INDEXES |
SDE_logfiles table column indexes storage definition |
| LF_STORAGE |
SDE_logfiles table storage definition |
| MAX_CACHED_CURSORS |
Maximum number of cached cursors |
0 or higher
0 = disabled
80
| MVTABLES_MODIFIED_INDEX |
Mvtables_modified index storage definition |
| MVTABLES_MODIFIED_TABLE |
Mvtables_modified table storage definition |
| RAS_STORAGE |
Raster RAS table storage definition |
| SESSION_INDEX |
ArcSDE session-based and stand-alone log file indexes storage definition |
| SESSION_STORAGE |
ArcSDE session-based and stand-alone log file tables storage definition |
| SESSION_TEMP_TABLE |
Controls whether or not log files get created in tempdb |
1 or 01 = create in tempdb
0 = don't create in tempdb |
| STATES_INDEX |
States table storage definition |
| STATES_LINEAGES_TABLE |
State_lineages table storage definition |
| STATES_TABLE |
| UI_NETWORK_TEXT |
User interface parameter, which indicates associated configuration keyword will appear in the ArcGIS user interface; contains description of network configuration |
Description up to 2048 characters |
| UI_TERRAIN_TEXT |
User interface parameter, which indicates associated configuration keyword will appear in the ArcGIS user interface; contains description of terrain configuration |
| UI_TEXT |
User interface parameter, which indicates associated configuration keyword will appear in the ArcGIS user interface; contains description of associated noncomposite configuration keyword |
| UI_TOPOLOGY_TEXT |
User interface parameter, which indicates associated configuration keyword will appear in the ArcGIS user interface; contains description of topoology configuration |
| VERSIONS_INDEX |
Versions table index storage definition |
| VERSIONS_TABLE |
Versions table storage definition |
| XML_DOC_LOB_SIZE |
Defines the size of the XML documents in the xml_doc column of the sde_xml_doc<n> table |
1 M |
| XML_DOC_STORAGE |
Storage clause for sde_xml_doc<n> table |
| XML_DOC_UNCOMPRESSED_TYPE |
When the XML_DOC_MODE parameter is set to UNCOMPRESSED, the XML_DOC_UNCOMPRESSED_TYPE parameter determines the storage format for XML documents |
Since XML_DOC_MODE is set to COMPRESSED by default, the XML_DOC_UNCOMPRESSED_TYPE parameter is not present by default. Possible values are BLOB, CLOB, or NCLOB |
| XML_DOC_VAL_LOB_SIZE |
Defines size of the XML document in the xml_doc_val column of the sde_xml_doc<n> table |
1 M |
| XML_IDX_FULLTEXT_CCSID |
Text index Coded Character Set Identifier (CCSID); specify the CCSID of the documents if the text documents are stored as binary. |
Consult your DB2 documentation for valid CCSID values. |
| XML_IDX_FULLTEXT_IDXDIRECTORY |
Path to text index directory |
Value depends on your directory |
| XML_IDX_FULLTEXT_LANGUAGE |
The language used for linguistic analysis when building the text index on the contents of the xml_doc_val column in the sde_xml_doc<n> table and the text_tag column of the sde_xml_idx<n> table |
There is no default value set for this parameter. Consult your DB2 documentation for valid language settings. |
| XML_IDX_FULLTEXT_UPD_COMMIT |
Index update commit_count |
AUTOMATIC or an integer greater than 0
(If set to 0, no commits are performed.)
Consult your DB2 documentation for more information on the COMMIT_COUNT option. |
| XML_IDX_FULLTEXT_UPD_FREQUENCY |
Index update frequency |
Number of days and hours index is to be updated
There is no default value set for this parameter. |
| XML_IDX_FULLTEXT_UPD_MINIMUM |
Minimum number of new or edited documents before full text index is updated |
There is no default value set for this parameter. If the value is left blank, the index will be updated for all additions/edits made during the update frequency. |
| XML_IDX_FULLTEXT_WKDIRECTORY |
Path to text index working directory |
| XML_IDX_INDEX_DOUBLE |
Storage clause for the xmlix<n>_db index on the double_tag column of the sde_xml_idx<n> table |
| XML_IDX_INDEX_ID |
Storage clause for the xmlix<n>_id index on the ID column of the xml_idx<n> table |
| XML_IDX_INDEX_STRING |
Storage clause for xmlix<n>_st index on the string_tag column of the sde_xml_idx<n> table |
| XML_IDX_INDEX_TAG |
Storage clause for the xmlix<n>_tg index on the tag_id column of the sde_xml_idx<n> table |
| XML_IDX_STORAGE |
Storage clause for sde_xml_idx<n> table (the index table of an XML column) |
| XML_INDEX_TAGS_INDEX |
Storage clause for xml_indextags_pk index of the sde_xml_indexes table |
| XML_INDEX_TAGS_TABLE |
Storage clause for sde_xml_index_tags table and the xml_indextags_ix1 and xml_indextags_ix2 indexes on the tag_name and tag_alias columns, respectively |
NOTE: For the XML parameters, <n> refers to the xml_column_id associated with a specific XML column.
