ArcGIS Server Banner
Feature datasets in a geodatabase stored in Oracle
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note:This topic was updated for 9.3.1..
Feature datasets are objects that allow you to group together related feature classes.
You would use a feature dataset to group feature classes that
Feature datasets contain feature classes as well as topologies, relationship classes, feature linked annotation, geometric networks, network datasets, schematics, terrains, and cadastral fabrics. In the train depot and railroad track example presented in the feature class topic, you could group these two related feature classes together by placing them in the same dataset. You could subsequently create a topology to define how these two feature classes interact.
Use the following links to read about different components of feature datasets in Oracle:
The following describes how a feature dataset would appear in ArcCatalog, in an Oracle DBMS, and in an XML document. Following that is a description of how topologies, networks, and terrains are represented in ArcCatalog, the DBMS, and XML.
Feature datasets in ArcCatalog
In the Catalog tree, feature datasets look like the following:
Feature dataset in ArcCatalog
This feature dataset is named Landuse and is owned by user GDB.
When the feature dataset is expanded in the ArcCatalog tree, you can see all the feature classes and other data objects that are in it.
An expanded feature dataset in ArcCatalog
Feature datasets in an Oracle DBMS
In the database, feature datasets are virtual collections of feature classes. They are grouped together by a common dataset ID, which is maintained in the GDB_FEATUREDATASET system table and associated with the GDB_OBJECTCLASSES system table. The dashed lines indicate an implicit relationship between tables.
Feature dataset system tables in Oracle
For the Landuse feature dataset example, the feature class SubParcels would be linked to the Landuse feature dataset through the GDB_OBJECTCLASSES table.
Because feature datasets are a virtual collection of objects, feature classes in feature datasets are just like stand-alone feature classes in that they have their own records in the GDB_FEATURECLASSES table and all the other tables associated with feature classes (such as LAYERS, TABLE_REGISTRY, GEOMETRY_COLUMNS, COLUMN_REGISTRY, and GDB_OBJECT_CLASSES). Since feature classes associated with feature datasets are database objects in their own right, they cannot have the same name as other tables or stand-alone feature classes in the same schema in the database.
Topologies, geometric networks, network datasets, and terrain datasets utilize additional system tables. These will be described in the corresponding sections that follow.
Feature datasets in an XML document
Feature datasets are grouped under the DatasetDefinitions tag in an XML document and separated by a DataElement tag of type FeatureDataset. The XML document entry for the Landuse dataset would look like the following:
<DatasetDefinitions xsi: type="esri:ArrayOfDataElement">
 <DataElement xsi:type="esri:DEFeatureDataset">
  <CatalogPath>/V=sde.DEFAULT/FD=GDB.Landbase</CatalogPath>
  <Name>GDB.Landbase</Name>
  <MetadataRetrieved>false</MetadataRetrieved>
  <DatasetType>esriDTFeatureDataset</DatasetType>
  <DSID>-1</DSID>
  <Versioned>true</Versioned>
  <CanVersion>true</CanVersion>
<Extent xsi:type="esri:EnvelopeN">
     <XMin>503924.656249088</XMin>
     <YMin>680110.56250334</YMin>
     <XMax>512514.562497088</XMax>
     <YMax>689084.187511697</YMax>
<SpatialReference xsi:type="esri:ProjectedCoordinateSystem">
  <WKT>PROJCS["NAD_1927_StatePlane_Alabama_East_FIPS_0101",GEOGCS["GCS_North_American_1927",DATUM["D_North_American_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-85.83333333333333],PARAMETER["Scale_Factor",0.99996],PARAMETER["Latitude_Of_Origin",30.5],UNIT["Foot_US",0.3048006096012192]]</WKT>
     <XOrigin>489871.255812</XOrigin>
     <YOrigin>665787.099562</YOrigin>
     <XYScale>499999.999534338</XYScale>
     <ZOrigin>0</ZOrigin>
     <ZScale>8192</ZScale>
     <MOrigin>0</MOrigin>
     <MScale>8192</MScale>
     <XYTolerance>6.56166666666667E-04</XYTolerance>
     <ZTolerance>2</ZTolerance>
     <MTolerance>2</MTolerance>
     <HighPrecision>true</HighPrecision>
   </SpatialReference>
  </Extent>
    </SpatialReference>
   </DataElement>
...all other DataElements...
</DatasetDefinitions>
Top of page
